Register private application (script) -> Access token
in Integrations
I'm trying to create a "private application" (script) following "TeamViewer API Documentation"
When you register the application you have to specify if you want to use it for your own account only (private ap-plication, also referred to as “Script”)
Registering the script should return an access token:
When you register an application for your own use only, you will get an access token that can be used di-rectly for any API function that requires it
Not access token is being returned, i'm receiving a client-id and client-secret:
Kind regards,
