Are there parameters to start TeamViewer?
Thilo
Hi all
How do I reset all options in a Teamviewer installation to default?
Thilo
Hi @Thilo!
Try uninstalling and re installing. When uninstalling there should be an option to save settings for re-installment.
Hope to have helped,
James
2 -
Hi James
The reset is for the the remote computer. I am looking for something that does not require loosing control of it.
There is nothing under "Options".
Is there a command prompt startup switch?
Can one delete the .INI file? Would it be recreated automatically?
Thilo
1
