I see 'Commercial use suspected' / 'Commercial use detected'
I purchased a Business License but every endpoint I try to connect to gives me the "Commercial Use Detected" Msg.
Yes I am using it Commercially but I purchased a license. Why doesnt it reconize this?
  • Esther
    Esther Posts: 3,505 Community Manager 🌍
    Hi bob1285,
    in this Knowledge Base article you can find out how to activate your Business-license on your devices: How to activate Business license
    You just need the license on one side of the connection to have a licensed connection. This should solve the issue for you.
    Best, Esther
  • bob1285
    bob1285 Posts: 2
    I do have a business license on one pc but when I try to access an endpoint pc it gives me message "commercial  use detected and will boot me off after 5mins
    Please tell me what I am doing wrong and how to solve this issue.
  • Esther
    Hi @bob1285
    Please make sure, that you are using the same TeamViewer version on both devices accordingly to the license version you are having.
    For example: If your Business-license is valid for TeamViewer 10, please use TeamViewer 10 on your device and the endpoint. If your Business-license is valid for TeamViewer 9, please use TeamViewer 9 on your device and the endpoint. And so on.
    If you would like to work with TeamViewer 12, you can update your license in our webshop.
    All the best, Esther
