Team Viewer for Ubuntu Server 18.04.4 running on Raspberry Pi
I'm running Ubuntu Server 18.04.4 LTS (64bit) for Raspberry Pi from https://ubuntu.com/download/raspberry-pi on a Raspberry Pi 3 Model B+ (https://ubuntu.com/download/raspberry-pi/thank-you?version=18.04.4&architecture=arm64+raspi3). I downloaded Team Viewer Host for Raspberry Pi from https://www.teamviewer.com/en/download/raspberry-pi/ . Unfortunatelly I the installation failed.
$ sudo dpkg -i ./teamviewer-host_armhf.deb
dpkg: error processing archive ./teamviewer-host_armhf.deb (--install):
package architecture (armhf) does not match system (arm64)
Errors were encountered while processing:
Seems like Team Viewer for Raspberry Pi is for armhf architecture only. I need the package for either amd64 or aarch64 instead.
$ uname -a
Linux ubuntu 5.3.0-1017-raspi2 #19~18.04.1-Ubuntu SMP Fri Jan 17 11:14:07 UTC 2020 aarch64 aarch64 aarch64 GNU/Linux
Is there a package built for my needs already?
Domenico Langone
MCSD: App Builder
Hi @DomLan ,
I already tried. Unfortunatelly the installation fails as well:
$ sudo dpkg -i ./teamviewer_amd64.deb
dpkg: error processing archive ./teamviewer_amd64.deb (--install):
package architecture (amd64) does not match system (arm64)
./teamviewer_amd64.deb0 -
Hi @fkromer
I do some verification and update you. Actually for the PI distribution it indicates v2 or higher
What kind of PI do you have?
Domenico Langone
MCSD: App Builder
Hi @DomLan ,
I have Raspberry Pi 3 Model B+ (v3) https://www.raspberrypi.org/products/raspberry-pi-3-model-b-plus/ .
Hi @fkromer,
here there is a specific section for installing on Linux device: Older 64-bit DEB-systems without Multiarch (Ubuntu 12.03, Debian 6 and below) - and a mention for your wrong architecture message
Try it.
Let me know!
Domenico Langone
MCSD: App Builder
Hi @DomLan ,
I've tried something mentioned in some other posts. However it did not work:
$ sudo dpkg --add-architecture armhf
Selecting previously unselected package teamviewer-host:armhf.
(Reading database ... 104510 files and directories currently installed.)
Preparing to unpack ./teamviewer-host_armhf.deb ...
Unpacking teamviewer-host:armhf (15.3.2682) ...
dpkg: dependency problems prevent configuration of teamviewer-host:armhf:
teamviewer-host:armhf depends on libc6 (>= 2.17).
teamviewer-host:armhf depends on libdbus-1-3.
teamviewer-host:armhf depends on libqt5gui5 (>= 5.5) | qt56-teamviewer.
teamviewer-host:armhf depends on libqt5widgets5 (>= 5.5) | qt56-teamviewer.
teamviewer-host:armhf depends on libqt5qml5 (>= 5.5) | qt56-teamviewer.
teamviewer-host:armhf depends on libqt5quick5 (>= 5.5) | qt56-teamviewer.
teamviewer-host:armhf depends on libqt5dbus5 (>= 5.5) | qt56-teamviewer.
teamviewer-host:armhf depends on libqt5webkit5 (>= 5.5) | qt56-teamviewer.
teamviewer-host:armhf depends on libqt5x11extras5 (>= 5.5) | qt56-teamviewer.
teamviewer-host:armhf depends on qml-module-qtquick2 (>= 5.5) | qt56-teamviewer.
teamviewer-host:armhf depends on qml-module-qtquick-controls (>= 5.5) | qt56-teamviewer.
teamviewer-host:armhf depends on qml-module-qtquick-dialogs (>= 5.5) | qt56-teamviewer.
teamviewer-host:armhf depends on qml-module-qtquick-window2 (>= 5.5) | qt56-teamviewer.
teamviewer-host:armhf depends on qml-module-qtquick-layouts (>= 5.5) | qt56-teamviewer.
dpkg: error processing package teamviewer-host:armhf (--install):
dependency problems - leaving unconfigured
Processing triggers for mime-support (3.60ubuntu1) ...
$ sudo apt --fix-broken install
Reading package lists... Done
Building dependency tree
Reading state information... Done
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
golang-docker-credential-helpers libpython-stdlib libpython2.7-minimal
libpython2.7-stdlib libsecret-1-0 libsecret-common python python-asn1crypto
python-backports.ssl-match-hostname python-cached-property python-certifi
python-cffi-backend python-chardet python-cryptography python-docker
python-dockerpty python-dockerpycreds python-docopt python-enum34
python-funcsigs python-functools32 python-idna python-ipaddress
python-jsonschema python-minimal python-mock python-openssl python-pbr
python-pkg-resources python-requests python-six python-texttable
python-urllib3 python-websocket python-yaml python2.7 python2.7-minimal
Use 'sudo apt autoremove' to remove them.
The following packages will be REMOVED:
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 55.2 MB disk space will be freed.
Do you want to continue? [Y/n] Y
(Reading database ... 104630 files and directories currently installed.)
Removing teamviewer-host:armhf (15.3.2682) ...
Processing triggers for mime-support (3.60ubuntu1) ...Obviously the package was not installed correctly and was removed:
teamviewer-host:armhf0 -
tested on- Raspberry Pi 3 Model B- Ubuntu 18.04.4 (arm64)
$ wget https://download.teamviewer.com/download/linux/teamviewer-host_armhf.deb
$ dpkg --add-architecture armhf
$ apt-get update
$ dpkg -i teamviewer-host_armhf.deb
$ apt-get --fix-broken install
$ dpkg --add-architecture armhfIt seems ok but$ teamviewer
Init...
Error: CheckCPU: unknown architecture 'aarch64'0 -
Did you ever resolve this? I have the same issue, but on a Pi 4 and Ubuntu 20.04
This issue applies to any arm64 device.
See: https://www.myzhar.com/blog/tutorials/teamviewer-14-on-nvidia-jetson-tx2/
hI @themreza
This link looked promising, but after installation, the TV didnt open..
any idea when TV will be released for jetson xavier arch armv8?
