What does "System Update" track?
I've set up a few computers for Remote Management using TeamViewer, and I've set up my Policy to monitor if System Updates are disabled, or if System Updates are available. I have two computers that are both fully patched ("Patches" under "Asset Management" shows no missing patches), but under Monitoring both computers show up as "Update Available".
So what updates is the "System Update" field tracking?
Windows implemented several changes in operating system update mechanism and due to that in the system logs some time temporary updates are coming up and because of that System update check is reporting that update is available. We are currently implementing improvements in our system check logic so that it can be compatible with new logic of OS updates. The fix is ready and currently is in testing phase. probably will be released during next week.
We apologize if the issue have caused you any inconvenience.
With Best Regards,
LevonProduct Owner, Remote Management0
