[Linux] v15.4.4445 (Full) - Change Log
Nadin1
Nadin1 Posts: 422 Moderator
Operating system: Linux
Version: 15.4.4445
Release date: 2020-03-24
Change Log:
New features
  • The possibility to send key combinations such as [Alt]+[Tab] or [Windows]+[R] is now available!
    When connecting from Linux to Windows, it's now possible to transmit various key combinations: switching the applications on Windows by using [Alt]+[Tab], opening the run command with [Windows]+[R], and so on.
Bugfixes
  • You can no longer start a direct file transfer to a remote system with restricted folder permissions (like macOS 10.15) without allowing full disk access in advance to prevent the client from becoming unresponsive. Within the session you need at least the possibility to view and control the remote screen on restricted systems.
UPDATE: I have a new Community Account: Please find my content under Nadin_W
  • swisstico
    swisstico Posts: 1
    Hot keys not working with Gnome 3 and Wayland...
  • MTNCOMP
    MTNCOMP Posts: 2 ✭✭
    Works like a charm on Linux Mint 19.3 to Windows 10 v1909. Thank you so much. Please tell the support people thank you for taking my suggestion just a month ago.!! #blessed #awesomeness #linux_mint
  • MTNCOMP
    MTNCOMP Posts: 2 ✭✭
    bummer. I am sure someone will check it out. be sure to submit a ticket if you can.
  • nicohell
    nicohell Posts: 4 ✭✭
    Since end of January and V15.0.8397 screen switch is not working both sides.
    I opened a ticket [#33331204] but no patch about this...
  • stephanelgr
    stephanelgr Posts: 1
    In this version (under linux mint 64bits) I lost in communicate section the sound on the remote computer.
    In my previous version (v12) I had it
    kinds,
