Team viewer not accepting password
This morning, I set up a session on my home PC, took a screenshot of the ID and Password. I get to work to connect to the session and it keeps saying the password is invaild. I know im typing it right as I have it in a screenshot, and there are no power settings that would set my PC at home to turn off.
Any Ideas? Tad frustrating, is there a time out set for the passwords within the sessions? Do they auto refresh?
  • Reyhan
    edited January 2023
    Hi @Vikx993
    Thank you for your post. Please note, that the random password will change after each remote connection or restart of TeamViewer.
    It is a better to add a personal password for unattended access, please have a look at this article in our Knowledge Base.
    Best regards.
    Reyhan
    Reyhan
  • ksierra
    ksierra Posts: 1
    I set up a personal password on the computer and turn off all hibernating ,stand by and sleep mode on the computer. But after working for a week, today i have a error that says invalid password. What could happend?
  • ArielAbaca
    I am having the same exact problem with a Windows Server 2012 host that has the last TeamViewer installed. I allows connections from the LAN with whatever passwords I use (I mean the ones I define personally or those the program randomnly generates). But when I try to connect from the Internet using the TeamViewer's ID, I keep falling in the authentication dialog because my password is not recognized. I have collected the log so you can follow along the problem.
    2018/08/02 09:53:52.812  5604  6080 S0!! Encryption.RSADecrypt exception: RSA/EME-PKCS1-v1_5: invalid ciphertext
    2018/08/02 09:53:52.812  5604  6080 S0!!!CEncryption::DeCryptBCommand(): decrypt CMD_BUDDY_ENCRYPTED failed!
    2018/08/02 09:53:52.812  5604  6080 S0!! CProcessCommandHandlerKeepAliveClient[9558]::CmdRequestRouteBuddy() DeCryptBCommand failed!
    Thanks a lot for taking the time to answer. Regards from Argentina. Ariel.
  • Billy60
    Billy60 Posts: 1
    Same problem here. I had been accessing remotely for exactly one week. Now I get an invalid password message.
  • kevstor996
    I dont understand this. I have a windows10 machiine with a password on that I remote into. I rebooted it this morning and then tried to connect remotely using the windows password (after connecting using teamviewer). I know my passowrd is ocrrect but it wont log me on?
    When I go home and log in to the machine direct it will let me on. I also tried the on screen keyboard but that didnt work.
  • Stuyvenstein
    I also cannot connect, it says the Password is invalid (After I just signed in using my Teamviewer account) and the machine that I am trying to connect to is set up for unattended access.
  • Artificer
    I have been encountering the same problem with the web connector. Then I try the exact same password on the chrome extension and it works. Seems to be a problem with the web connector.
  • pjbaker
    pjbaker Posts: 2
    My online account will accept my password for the account but not the app on my mac book.  What is weird, is if I log into teamviewer online through a web browser and then go to connect to another device, the browswer will ask to open the app.  When I click allow, the browswer will open the app and automatically submit the password and the whole app functions find until my computer times out, then I have to go through this whole procedure again to get teamviewer app to work, which is the only way for my mac to connect to a remote computer.
  • MilwNick23
    I just put the app on my phone and encountered the same problem..  Did you ever get an answer that works?
    I appreciate your help!!
    -Nick
  • mrdrking
    mrdrking Posts: 1
    I have similar issue on PC as PJBaker on the Mac.
    Background ... this is a new installation of Win 10 on an older PC, thus a recent install of Teamviewer.
    ... it sounds like PJ & my experiences are consistent, but there may be other issues, ... like getting the new install of program in PC included / activated in the Teamviewer 'my computer user group' .... or perhaps a slightly different formal name (since I cant get there)
    thanks for solution(s)
  • dmthompson
    dmthompson Posts: 1
    Still no resolution to the same problem. It says that the password is invalid, although we tried it three ties even updating the password.
  • juancuero
    juancuero Posts: 2 ✭✭
    The 'passwort' is also invalid
    "passwort invalid - validation failed [E14]"
  • BrBill
    BrBill Posts: 1
    I'm still having this problem a year later, and the article @Reyhan posted is a dead link. "The article has been deleted."
    So what's the RIGHT answer?
