Infinte loop between tabs
fschons
Hi guys, I'm trying to have a presentation on my client monitor with loop between tabs (power point + IE). Although when I select to have it it's just showing one, either the power point or IE.
The command ''ALT+TAB'' is working but I want it to keep showing all open tabs when I'm not connected anymore.
Is that possible?
Hi @fschons
Do you mean that you want to interact with the remote pc by pressing Alt+Tab without having a connection enabled?
If this is what you mean, then I'm afraid that this is not possible, because after the connection ending, you have not any other access to the remote pc.
You have to reconnect again if you want to access it.
Best regards
