How to find already existing entry in buddylist
In the Management Console I get an error "BuddyAlreadyExists: 12" while trying to rearrange our 50 Lists with over 1000 entries. (Some folders were created by deprecated users, which is why we now want to merge/move the entries)
Is there a way to find the already existing Buddy without klicking every single ones property and check the TV-ID?
The searchfield doesn't find IDs...
Greetings and thanks from Germany.
  • You are right! Sorry and thank you...
    I've copied the ID from the properties and there was a little "space" at the end - so the searchfield showed me nothing.
    My fault.
  • Esther
    Top - thanks for your reply!
    I am glad to hear we could "fix" it that quickly ?
    Have a great day,
    Esther
  • RandGonzalez
    RandGonzalez Posts: 4 ✭✭
    Hi Im having the same error: 'This buddy is already in your buddy list' (BuddyAlreadyExists: 12).
    Im just trying to change the user from one group to another.
