Hello all,
today we had a conference call in which we needed a person to be present who was in his car and didn't have the Blizz app installed, so he tried to join by dialing in the number, but because of all the steps had would have to go through with pressing the number for the language or putting in the code he wasn't able to join since he had to drive his car, so in the group the question occurred if you could just join by putting in the number and the code behind it with a comma inbetween, like skype does it. Another question the came up in the same call was if you are able to be logged into multible accounts at the same time so then if you need to join a call on the other account you can just hop into it instead of logging out with one account and then logging in with the other.
Thanks for any replys in advance.
Bennn
