Cannot switch between available monitors
Cyrael
I had to update my computer last night, which apparently also updated Teamviewer. Now I cannot change which monitor I'm viewing.
There used to be a button in the mini-menu here for quick-swapping between monitors
And there used to be an entire section called Monitors here, which is also mysteriously missing.I'm running version 12.0.78313
Oddly enough, my other computer is running the exact same version and yet these are not missing there.
Ah, my monitor cable became loose and it no longer detected the second monitor.
6
6
