Auto-reconnect after a remote reboot no longer works?
ctrl-alt-mat
ctrl-alt-mat Posts: 4
Hi all, I'm a registered user running the latest full version V13 on my end and my remote clients are using the QS version. It seems that whenever I initiate a remote reboot of a machine I can no longer auto-connect back to that machine, the remote user needs to authorise the connection again and it's a pain. Previoulsly, if I initiated a remote reboot of a computer I was automatically connected back to it after hitting the "Reconnect" button. As anything changed? Am I doing something wrong/diffferent than before?
Thank you all for your time and support,
Mathieu
  • makarmia
    makarmia Posts: 2
    In my setup (teamviwer teamviewer 15.6.7 on two Ubuntu 18 machines) the remote reboot option in Actions is grayed out. I am looking for solution for some time now. I can restart the remote, but not reconnect to it. I have to physically access the remote after each reboot.  Help will be much appreciated.
  • dannytew
    dannytew Posts: 1
    I have the same issue:
