Teamviewer 13 not connecting in Ubuntu 18.04 Login Screen
I installed Ubuntu 18.04, and I noticed that in the Login Screen Teamviewer (teamviewer_13.1.3026_amd64) is not connecting.
However, when I log in then Im able to use Teamviewer.
I didn't have this issue with Ubuntu 16.04 and teamviewer_13.1.3026_amd64.
I'm having the same issue. I can log in, but won't connect to host.
I get a similar issue. After reboot, I cannot connect via Teamviewer.
Following manual login, Teamviewer is able to connect at the login screen until the next reboot.2 -
Same here. On Ubuntu 18.04 bootup, Teamviewer 13 does not start. Starts after login.
<TL;DR>
sudo gedit /etc/gdm3/custom.conf
Uncomment this line in custom.conf file:
WaylandEnable=false
and Reboot.
<TL;KH> (Know How)
For some reason B E A V E R word is not allowed to post, it turns it into bionic-**bleep**-linux
Though I'm not sure what a Wayland Display Server is I found a workaround/solution in these pages.
How-to-install-teamviewer-on-ubuntu-18-04-bionic-linux
"If you see the warning message Wayland Detected your TeamViewer version does not fully support Wayland display server yet. As message also suggests, this is only troublesome in case you need to establish incoming connection from another TeamViewer client. If this is your case you need to disable wayland and enable Xorg display server before you can accept incoming transmissions."
and workaround is here:
How-to-disable-wayland-and-enable-xorg-display-server-on-ubuntu-18-04-bionic-linux
6 -
Hi there, thanks for the hint. I removed beaver from the filter.
Best, EstherCommunity Manager0 -
That worked. Thank you!
2 -
That workaround link is 404.. can someone transcribe post relevant information?
Links are 404 because Teamviewer forum didn't allow me to write full urls as in their content have beaver word.
https:// linuxconfig.org/how-to-install-teamviewer-on-ubuntu-18-04-bionic-**bleep**-linux
Substitute the **bleep** by beaver word.0 -
<TL;DR>
WaylandEnable=false
and Reboot.
I can confirm with TeamViewer 14 and Ubuntu 18.10 that this works
Thanks bobgutierrez.
It solved the problem on my Ubuntu 20.04 LTS and TeamViewer 15.6.7
Best Regards,
Jocafi
this problem is not only un Ubuntu i have it on
Arch
Manajro
Ubuntu
Debian
Fedora1 -
This works for Ubuntu 20 And Teamviewer 15.
@bobgutierrez wrote:<TL;DR>
WaylandEnable=false
and Reboot.
