Turning off patch deployment after trial of software
I ran a trial of the Remote Management that has since expired, but the devices are still running weekly patch deployments and emailing me. At 100+ devices thats a lot of emails.
I would like to turn these off but obviously have no access anymore.
Can I either have a brief turn on of the service so I can remove the settings, or can you do this for me please.
  • antald
    antald Posts: 4 ✭✭
    Same here, even with license the remote monitoring and patch management software is not uninstalled or disabled when there is no license.
  • Levon
    Levon Posts: 48 Staff member 🤠
    After trial expiration, both Monitoring and Patch Management services should be uninstalled automatically. If the issue still exists for you please open a ticket and together with our support colleague's support we will have a look at the described situation.
    Levon
    Product Owner, Remote Management
