After installing Teamviewer on Ubuntu got Apache/Network problem
Hi, I use VPS to host site and in parallel I use its visual shell using the browser in it.  It would be more convenient for me to connect to it through Teamviewer and I decided to install it on the server, I find this post - https://community.teamviewer.com/t5/Knowledge-Base/How-to-install-TeamViewer-on-Ubuntu/ta-p/45, and it works fine, but I began to notice that a certificate error started to appear on the site(you can check - http://1x-rate.com/), and then I noticed that it appears exactly when I was logged off to the server through Teamviewer. Is this a coincidence or can these problems be related?
  • harville
    harville Posts: 2
    Woohoo! It's help!!! After Teamviewer take 439 port Apache really response an error in case of  conflict, so I setup apache to reconnect for 443 port if this conflict appear and it work fine. Thank you very match! Good luck!
  • Vatsilidis
    Vatsilidis Posts: 655 ⭐Star⭐
    Thanks for the update @harville !
    You are very welcome!
