Team Viewer for Ubuntu Server 18.04.4 running on Raspberry Pi
I'm running Ubuntu Server 18.04.4 LTS (64bit) for Raspberry Pi from https://ubuntu.com/download/raspberry-pi on a Raspberry Pi 3 Model B+ (https://ubuntu.com/download/raspberry-pi/thank-you?version=18.04.4&architecture=arm64+raspi3). I downloaded Team Viewer Host for Raspberry Pi from https://www.teamviewer.com/en/download/raspberry-pi/ . Unfortunatelly I the installation failed.
$ sudo dpkg -i ./teamviewer-host_armhf.deb
dpkg: error processing archive ./teamviewer-host_armhf.deb (--install):
package architecture (armhf) does not match system (arm64)
Errors were encountered while processing:
Seems like Team Viewer for Raspberry Pi is for armhf architecture only. I need the package for either amd64 or aarch64 instead.
$ uname -a
Linux ubuntu 5.3.0-1017-raspi2 #19~18.04.1-Ubuntu SMP Fri Jan 17 11:14:07 UTC 2020 aarch64 aarch64 aarch64 GNU/Linux
Is there a package built for my needs already?
Hi @fkromer,
try standard Ubuntu (Debian) package
Regards.
MCSD: App Builder
Hi @DomLan ,
I already tried. Unfortunatelly the installation fails as well:
$ sudo dpkg -i ./teamviewer_amd64.deb
dpkg: error processing archive ./teamviewer_amd64.deb (--install):
package architecture (amd64) does not match system (arm64)
Hi @fkromer
I do some verification and update you. Actually for the PI distribution it indicates v2 or higher
What kind of PI do you have?
MCSD: App Builder
Hi @DomLan ,
I have Raspberry Pi 3 Model B+ (v3) https://www.raspberrypi.org/products/raspberry-pi-3-model-b-plus/ .
Hi @fkromer,
here there is a specific section for installing on Linux device: Older 64-bit DEB-systems without Multiarch (Ubuntu 12.03, Debian 6 and below) - and a mention for your wrong architecture message
Try it.
Let me know!
MCSD: App Builder
Hi @DomLan ,
I've tried something mentioned in some other posts. However it did not work:
Obviously the package was not installed correctly and was removed:
Did you ever resolve this? I have the same issue, but on a Pi 4 and Ubuntu 20.04
This issue applies to any arm64 device.
See: https://www.myzhar.com/blog/tutorials/teamviewer-14-on-nvidia-jetson-tx2/
hI @themreza
This link looked promising, but after installation, the TV didnt open..
any idea when TV will be released for jetson xavier arch armv8?
