No sound from remote computer
2»
  • FlorenceJ
    FlorenceJ Posts: 3 ✭✭
    @mparker wrote:
    I believe sound flower is now loop back.  Also look at audio hijack
  • I have a usb interface connected to my laptop so that I can use external speakers. This works for every application except for teamviewer, which still routes audio to the laptop speakers. This happens regardless of the audio settings I choose in teamviewer or on the operating system level. Is it possible to make teamviewer correctly route audio to my interface like every other application?
  • mparker, can you describe in detail how you employ loopback to do this? Are you getting this to work on a Mac?
  • This is unacceptable! should've been told when I purchased the licence!
  • Right on!
  • aviduser
    aviduser Posts: 1
    Hi everyone!
    Why can't I hear the sound of the remote machine in the following cases:
    control machine: PC, remote machine: MAC
    -control machine: MAC, remote machine: MAC
    Only the remote machine has sound if both the control machine is a PC and the remote machine is a PC
    I think MAC users also rightly expect to hear the sound of the remote machine as well.
    I have already looked through all the settings but the function does not work.
    Anyone have any ideas?
    Best regards: Gabor
  • anonymous12
    anonymous12 Posts: 4 ✭✭
    edited June 2023
    I want to work between a Mac and a PC. I can't use a phone because reception is poor. I can work from a Mac to a Mac. I'm glad to turn off Teamviewer's sound, but I can't then use Skype or Google Voice. Suggestions?
  • fmw42
    fmw42 Posts: 3 ✭✭
    The answer that there are technical issues with Mac seems to me to be cop-out. This only happens with the new version of TeamViewer. I was happily hearing and sending audio on the older TeamViewer between my Mac and a PC. Why is it any harder now?
