I have a few computers i can not connect to, it tells me i am blacklisted or not white listed
Announcements
Remote Control for all devices running Android 7+ is here!
(Incl. Google Pixel series, Xiaomi smartphones, Oppo devices, and many more)
Learn more
Highlighted
Posted by
Henagon
We don't have blacklist or whitelist on any of our computers.
S0   UHP.DNS Resolution failed with system:11004:The requested name is valid, but no data of the requested type was found!
G1   CLoginClient::NegotiateVersionClient()
G1   LoginOutgoing: starting authentication
G1   LoginOutgoing: authentication denied
G1   Login.AuthenticateClient: blacklisted
S0   Carrier[2]::CmdEndSession(): Received CMD_ENDSESSION with reason: LoginFailed
S0   SessionStatistics[2] Session to **Please do not post TeamViewer IDs** ended. Estimated capacity=192685kBit/s, Latency=0ms
S0   UDPv4: [2]: create udp connection was not successful: UdpHolePuncher shutting down: (*)
S0   UDPv6: [2]: create udp connection was not successful: UdpHolePuncher shutting down: (*)
S0!  RemoteSession[2]::AddRequestedCarrier(): request carrier UdpToPartner failed!
 I have found I can’t remote control computers if I don’t see all 4 options (remote control – prompt for psw, remote control using password, presentation, video call).  i.e. only Remote control using password shows when i click on their Computer under Computers and Contacts.
1 Reply
1 Accepted Solution
Accepted Solutions
Highlighted
Posted by
Henagon
Solution
Re: I have a few computers i can not connect to, it tells me i am blacklisted or not white listed
there was a policy on some of the workstations that blocked all users except certain email addresses.  i was signed in with a different address.
problem solved.
View solution in original post
1 Reply
Highlighted
Posted by
Henagon
Solution
problem solved.
