Posted by tbostwickhubb
Henagon
Premium/Corp License - connection to my licensed device from abroad
Considering the Premium or Corp license, I would continue to use the software on my workstation, to connect to endpoints already established which is how I see this working primarily.  However, when I'm not at work I also want to connect to my workstation directly
(remotely) or in an emergency when I can't travel to my workplace
 Will either license allow me to do that ?  Again, there'd only 1 concurrent user (me) in this situation - even if I need to bring in 3rd party support personnel as needed, I can give out the TV ID and temp password to any endpoint if need be.
Please advise
Thanks,
tbostwickhubb
1 Accepted Solution
Accepted Solutions
Posted by Community Manager
Solution
Re: Premium/Corp License - connection to my licensed device from abroad
Hi @tbostwickhubb
I recommend you to call our Sales department to get the most suitable license for your needs. Click here to find the contact information.
But just from what you wrote, the Premium license would be sufficient.
Esther
Solution
Hi @tbostwickhubb
Esther
Henagon
Thanks for the quick update - I'll contact Sales support for TeamViewer.
Todd
