Posted by teamviewerneeb
Henagon
Teamviewer 12: Is there a way to save a resolution for Clients in the "my computers" list?
Hi there,
this is the first post ever :-)
I have an annoying problem with teamviewer: I have serveral Computers (i.e: Teamviewer IDs) linked to my "master" Account. I use it to connect to multiple computers across my home.
It all works great save for one really annoying problem: Teamviewer always defaults to a low resolution and more egregiouly a 4:3 aspect ratio. Is there a way to save resolutions for you Clients?
1080.pngIt should default to this :-)
Team.pngThis is the list of "my computers"
1 Accepted Solution
Accepted Solutions
Henagon
Solution
Re: Teamviewer 12: Is there a way to save a resolution for Clients in the "my computers" l
Thanks again; and i figured out a workaround myself: Just set it up on a windows pc;
Once the selected resolution is saved it also works on mac ;-)
BR
Posted by Community Manager
Hi @teamviewerneeb
And thank you for your post :-)
In the properties of the devices in your Computer & contacts list you have the possibility to define different individual settings incl. remote resolution:
 Here you can choose the perfect resolution for your device.
Just click on the gear-weal beside the Computer name in your Computers & contacts list.
Please excuse that I am using this post as a chance to recommend you to change the layout of your TeamViewer to the new and improved interface to have an even better TeamViewer experience: Options --> General --> Enable "Use new user interface" --> OK and restart your TeamViewer
I hope you like it :-)
All the best, Esther
Henagon
First of all: Thanks alot. I switched to the new UI ;-)
_.pngThe described option is not displayed?But the recommendation you gave me is simply not display in my teamviewer app ;-( (see picture below). Maybe its because i'm a mac user? Is there a way to fix that?
BR
Hi again,
I am sorry, I did not pay attention to your OS :-(
Well, you are right: This option is not (yet) available for Mac. But: please feel free to add this as a feature request to our Ideas board to let our Product Management know, that you need this feature as well.
Thank you and have a great weekend, Esther
Henagon
Solution
BR
Posted by JoshFreeman
Henagon
Can we please get this option, since you've **bleep** up the resolution settings and now it resizes to 1280 everytime...
Also would like it on ipad...
Posted by xerces8
Digon
Where do I find the "Computer & contacts list" ?
I have TV 13 on Windows and can't find it.
Edit: Found it, it appears after signing in to the TV account.
Posted by DaveBoston
Henagon
So will setting screen resolution ever come to macs for TV12?
