Posted by Emre
Digon
Fedora 25 - Teamviewer 12 Remote Access Problem
Hey all,
I'm using fedora 25 workstation with gnome desktop. I did graphical installation without any problem. When try to access another pc TV works fine but  when try to access my pc   password screen does not appear and i get  "wait for connect failed" error.
1 Accepted Solution
Accepted Solutions
Posted by TeamViewer Staff
TeamViewer Staff
Solution
Re: Fedora 25 - Teamviewer 12 Remote Access Problem
Dear Emre,
Thank you for your feedback.
The reason that you're not able to use TeamViewer before login is that gdm loads TeamViewer after login.
If you need to use TeamViewer before login, you need a DM that it's able to launch the application before you log in, like lightdm or sddm does.
To fix your issue, you need lightdm as your display manager instead of gdm.
Please follow these instructions to fix your issue.
sudo yum install lightdm lightdm-gtk
sudo systemctl disable gdm.service
sudo systemctl enable lightdm.service
reboot
View solution in original post
TeamViewer Staff
 Dear Emre,
To be able to understand your issue better, what's the status of your Fedora Box that you're trying to connect into?
Is it just booted and waiting for login? Is it already in a session or just logged out after a session?
Please let us know the output of the following command
cat /etc/systemd/system/display-manager.service | grep -i execstart=
We are looking forward to your comments.
Have a great day!
Christian
Posted by Emre
Digon
Hello Christian,
output of the command  is :
ExecStart=/usr/sbin/gdm
TeamViewer Staff
Solution
Dear Emre,
reboot
Posted by Emre
Digon
Dear Christian,
These instructions  fixed my problem :smileyhappy:
Thank you for your help and attention
-Emre
