Announcements
Shape the future of your TeamViewer product with our Product Team. Click here to join!
Posted by alecrugar
Henagon
Android SDK integration
is there any tutorial covering this topic?
I've downloaded the SDK for Android Studio and read the README.md file.
I added the ScreenSharingSDK.aar file to my project and modifies the gradle files.
Now I want to implement the screen sharing and remote control features, but the documentation link is down
For a complete tutorial, please refer to the [Android tutorial]
(http://integrate.teamviewer.com/develop/screen-sharing-sdk/android-tutorial) on the
TeamViewer Integrations Website.
 Any ideas?
Posted by MitjaHenner
Digon
Re: Android SDK integration
The SDK is not really useable right now.
It only works with targetSdk 25 and below and right now you can only release apps with 26+ and in a few month only update apps with 26+.
Only have Kotlin files but maybe it helps:
Implement the interface in your Activity and you should be able to start the Session.
class ScreenSharing {
    private val SDK_TOKEN = ""
    private val CONFIGURATION_ID = ""
    private var runningStateListener: RunningStateListener? = null
    var isSessionRunning = false
        private set(isRunning) {
            field = isRunning
            runningStateListener?.onRunningStateChange(isRunning)
    fun setRunningStateListener(listener: RunningStateListener?) {
        runningStateListener = listener
    fun startSession(activity: Activity, serviceCaseName: String, serviceCaseDescription: String) {
        try {
            val configuration = createConfiguration(serviceCaseName, serviceCaseDescription)
            TVSessionFactory.createTVSession(activity, SDK_TOKEN, createSessionCreationCallback(this, configuration))
        } catch (e: IllegalArgumentException) {
        } catch (e: IllegalStateException) {
    private fun createConfiguration(serviceCaseName: String, serviceCaseDescription: String): TVSessionConfiguration {
        return TVSessionConfiguration.Builder(TVConfigurationID(CONFIGURATION_ID))
                .setServiceCaseName(serviceCaseName)
                .setServiceCaseDescription(serviceCaseDescription)
                .build()
    private fun createSessionCreationCallback(
            wrapper: ScreenSharing, configuration: TVSessionConfiguration): TVSessionCreationCallback {
        return object : TVSessionCreationCallback {
            override fun onTVSessionCreationSuccess(session: TVSession) {
                session.setTVSessionCallback(createSessionCallback(wrapper))
                session.start(configuration)
                wrapper.isSessionRunning = true
            override fun onTVSessionCreationFailed(error: TVCreationError) {
    private fun createSessionCallback(wrapper: ScreenSharing): TVSessionCallback {
        return object : TVSessionCallback {
            override fun onTVSessionEnd() {
                wrapper.isSessionRunning = false
            override fun onTVSessionError(error: TVSessionError) {
    interface RunningStateListener {
        fun onRunningStateChange(isRunning: Boolean)
    companion object {
        val instance = ScreenSharing()
Main:
class MainActivity : AppCompatActivity(), ScreenSharing.RunningStateListener
override fun onResume() {
        super.onResume()
        ScreenSharing.instance.setRunningStateListener(this)
override fun onPause() {
        super.onPause()
        ScreenSharing.instance.setRunningStateListener(null)
private fun startTeamViewerSession() {
        ScreenSharing.instance.startSession(this, "Test", "Test")
override fun onRunningStateChange(isRunning: Boolean) {
Posted by alecrugar
Henagon
Thanks a lot MitjaHenner, I really appreciate your help. Do you know where I can find the information that  the SDK only works with targetSdk 25 and below? Is there any official announcement? Thanks!
Digon
Nope, I found out when I tried to use the SDK and couldn't get it to work for hours.
Probably because of the "new" permissions.
Posted by alecrugar
Henagon
Alright thanks a lot :)
Posted by sscp
Henagon
Where can i found the ?
SDK_TOKEN = ""
Digon
I think you can generate them in the Management Console: https://login.teamviewer.com/LogOn
Posted by sscp
Henagon
I got only tokan from consol after created App with android sdk, but where can i found the CONFIGURATION_ID or how can i generate it?
Posted by sscp
Henagon
can i have get any sample code or documetation
Digon
Go to deploy on the management console:
https://login.teamviewer.com/nav/deploy
and click the "add quicksupport" button the Id you get after creating the quicksupport is your configurationId.
Download the SDK and in Android Studio: File -> New Module -> Import JAR/.AAR Package to import it.
In your build.gradle (app not project) add the dependency and remember to use targetSdkVersion 25 or lower.
dependencies {
    implementation project(": ScreenSharingSDK")
Example implementation (Kotlin again):
class MainActivity : AppCompatActivity(), ScreenSharing.RunningStateListener {
    override fun onCreate(savedInstanceState: Bundle?) {
        super.onCreate(savedInstanceState)
        setContentView(R.layout.activity_main)
        button.setOnClickListener { startTeamViewerSession() }
        super.onResume()
        super.onPause()
        ScreenSharing.instance.startSession(this, "Title", "Description")
            field = isRunning
        try {
                .build()
    companion object {
