Teamviewer9 stops working, does not connect and/or does not start since installing it on Windows10 v
Bräunig-Silicon
Teamviewer9 stops working, does not connect and/or does not start since installing it on Windows10 ver1809.
We use Teamviewer9 as our main business support tool and the fact that it is not compatible to a major windows 10 update makes it useless.
We need support.
Dear @Bräunig-Silicon,
TeamViewer 9 is not compatible with Windows 10 Version 1809.
On the following page, you will find the supported systems for V9:
Which operating systems are supported?For further questions, please contact us again.
NataschaGerman Community moderator 💙 Moderatorin der deutschsprachigen Community
