Announcements
We are happy to announce the launch of
TeamViewer Web Monitoring!
⇒  Learn more here ⇐
Highlighted
Posted by TeamViewer Staff
TeamViewer Staff
Re: I dont even get an ID or password ?
Hi @mcoates
Could you tell your Synology model?
Highlighted
Posted by
Henagon
Thank you its a 218J model   The cheap entry level home unit
Highlighted
TeamViewer Staff
@mcoates
It should run perfectly on DS218j. Is the package in running state in package center? Which package have you taken? And could you reinstall it and check again.
Highlighted
Posted by
Photon
Re: IoT Remote AppControl solution and Synology NAS boxes
Wow, I wasted 2 hours trying to get this to work, only to realize that buried in the fine print was the statement that this would not work with the Mac TeamViewer client.  Way to bury the lead!  Please call more attention to this, as it is not a minor detail!
Highlighted
Posted by
Photon
I am able to use Teamviewer in Parallels on my Mac to access all of our Synology's with Teamviewer. Minor inconveince but doable.
Do you have Parallels that you can try?
Highlighted
Posted by
Henagon
hi,
i have the same problem as mcoates.
My DS116 also doesn't get an ID or password. I use the the 1.1.1227 armv7 package. In the Package Centre is Teamviewer always shown as ready to start so the service isn't running. When i try to start Teamviewer, the status doesn't change.
any ideas?
Highlighted
Posted by
Henagon
I eventually got it to work, you just keep closing it down and restarting and after about three times it will come up with a username and password for you.
Be aware however as soon as you add it to your list of trusted devices it then goes off and demands you upgrade to a mobile licence !   I already have two business licenses and its wanting me to buy something else which I don't want and probably don't need. It refuses to connect unless you purchase a mobile licence which is probably something stupid like $40 a month. As soon as I saw this I just deleted it from my NAS
Highlighted
Posted by
Henagon
i already tried that (also reinstall), but no luck ...
Today i check the Log Files and i could only find 1 entry:
2019-05-20T10:11:02+02:00 backup synoscgi_SYNO.Core.Package.Installation_1_install[8336]: pkgtool.cpp:3033 Package TeamViewer stops but service pkgctl-TeamViewer start
any ideas?
Highlighted
TeamViewer Staff
That has been a bug and we hoped we fixed it some time ago. No mobile license should be required for connecting to NAS systems. Is this still happening to you? If yes, please contact support so we can fix it for you.
Highlighted
TeamViewer Staff
Hello@ar0na
I don't understand why its not working on your device. Do you have access to Synology Terminal (from Linux or Windows machine)?
Highlighted
Posted by
Henagon
hello arpitjindal,
sure i have a ssh connection. what do you need?
Highlighted
Posted by
Henagon
Hello, yes I have reinstalled the program on two separate devices and it is still demanding I have a mobile license even though I have two separate business licenses. The bug is still there and I have put a claim through the support system of your website. Thank you Michael
Highlighted
TeamViewer Staff
Hello @mcoates
Please contact to our support system. It should never ask for any kind of additional license.
Could you also please tell me your Windows TeamViewer version?
Highlighted
Posted by
Henagon
Thanks for the work.  Be sure to let us know when you have this working on platforms other than Windows.
Highlighted
TeamViewer Staff
Hi @jnjsdad
Yes, it will be announced when we support connections from other platforms.
Highlighted
Posted by
Digon
I use Teamviewer for personal use only, just at home and for occasionally accessing a couple of family members' PCs to help them with problems. I have a Synology NAS so thought I'd try the TM app for it, but after trying to run it tells me I need a license, and I also now have messages flashing up on my PC saying I am using it for commercial use!
Firstly, should I need a license to use it on a Synology NAS?
And secondly, how do I make sure my TV account IS set to personal use only?
Highlighted
Posted by
Henagon
When will Teamviewer 14 be available ?
Highlighted
TeamViewer Staff
Hi F1nchy!
You should be able to access your Synology with your free license just fine. If you are incorrectly recognised as a commercial user, please contact our support so they can fix that for you. If you are asked for a license while connecting, please also open a support ticket with your log files (from the Synology and from your client system) attached.
Highlighted
Posted by
Digon
Thanks for the reply. I've reinstalled TV on the Synology but when I  try to access it tells me I'm using it commercially still.
What's the easiest way to contact support? I can't contact via the website as I am a private user and it won't let me submit a ticket without a license!
Highlighted
Posted by
Henagon
Hello Group,
I just installed the beta version on my DS412+ ...
I have an ID but no password and I can't define one by myself ...
If i click "download support information" I got an error
The "remote Terminal" switch is OFF and gray ..unable to avtivate it ...
What's wrong with my team viewer ??
MERCI :)
Highlighted
Posted by
Digon
Is there a plan to update the TV in Synology devices to version 14? Seems I have upr-graded all of my computrs and can't connect to the DS218j. Should the Synology package (beta) work, or should I manually install the TV package?
Highlighted
TeamViewer Staff
Hi@Aktarus
Are you still facing this problem?
Highlighted
TeamViewer Staff
@mickwish
It should work with the current package. What is the error you are getting?
Highlighted
Posted by
Henagon
YES, it's still the same this morning .. :(
I got only the ID .. no password .. and If i try to connect tho this ID from another computer, I got an error ...
Highlighted
Posted by
Digon
I can add to my computers ok but then it fails to connect. It pops up a box to say upgrade it.
Highlighted
TeamViewer Staff
@mickwish
Could you post the screenshot?
And also, have you assigned the device to your account? For more information about the assignment process, read the first page of this forum
Highlighted
Posted by
Henagon
I second that issue - TV@Windows is simply unable to accept the password provided by TV@Synology, see:
@_Andreas_/ @arpitjindal please, once and for all, fix this mess!
Highlighted
Posted by
Electron
I didnt properly understandyour probem
Highlighted
Posted by
Henagon
How come?
The darn password, when entered into the "Assign to account" box, is declared wrong, hence no assignment possible, hence no connection possible.
I'm just fed up with how bad this is developed. Calling it beta, not issuing any update on weeks or even months and simply letting users on their own.
Oh and those g-o-d-d-a-m-n captchas, always requiring about 5 or more rounds - as if 2FA wouldn't be enough to secure - and proof! - that I'm a) a human and b) valid user.
Highlighted
TeamViewer Staff
Hi @Aktarus
At the moment I don't have any clue why password is not showing up. I don't see any reason in which this would happen. The only thing I could ask you to check from your side, at the moment, is that in your settings "protection against cross-site" is activated which you could find in "Control Panel"->Security ->"Improve protection against cross-site request forgery attacks" .
I would be needing more time for this. Meanwhile, you could directly take the serial number of your synology device("control Panel" -> "info center") for the password and assign the device to your account.
Highlighted
TeamViewer Staff
Hi @mickwish
If you are still facing the problem then could you please post the screenshot of the error?
Highlighted
TeamViewer Staff
Hi @ThreadRipper86
Could you please send me the logfile. To download the logfile, click on the "Download Support Information". Also, are you using the actual Synology device or the virtual DSM? If it is virtual DSM, then it is not supported by us.
Please download the logfiles twice, one before the making the assignment and one after the error happens due to the assignment failure.
Highlighted
TeamViewer Staff
Hello All TeamViewer Users,
Final TeamViewer package has been released for Synology, available directly from Synology package center. This package includes:
  1. Improvement in Remote Terminal
  2. Increase in performance.
  3. Minor bug fixes
Please download/update your Synology's TeamViewer package.
Enjoy :)
Highlighted
Posted by
Digon
Thank you! Now TV works as expected with my DS218j.  :)
Mickwish
Highlighted
Posted by
Henagon
@arpitjindal
I guess that makes downloading log files unnecessary. While it's technically nearly equal, you opted for not supporting Virtual DSM. Great, really.. not!
May I at least ask what's the ETA for such support?
Highlighted
TeamViewer Staff
Hi@ThreadRipper86
At the moment, We don't plan to support virtual DSM.
Highlighted
Posted by
Henagon
Synology 1512+
Is the Synology 1512+ supported? Which version i have to download it?
Highlighted
TeamViewer Staff
Re: Synology 1512+
Hi @Sniper8952
The new version is now being added in Synology package center. You could directly install it from there.
Highlighted
Posted by
Henagon
Re: Synology 1512+
Hi arpitjindal
If i install it, i can't connect with my PC Teamviewer to the Synology Teamviewer Server. My Computer can't find the Server.
Highlighted
TeamViewer Staff
Re: Synology 1512+
Hi @Sniper8952
Could you tell me what error are you getting? And also how are you connecting to it? Did you assign the device to your account first?
Highlighted
Posted by
Henagon
Re: Synology 1512+
A connection could not be established
Eine Verbindung konnte nicht hergestellt werden.
I connect in the same network.
Highlighted
TeamViewer Staff
Re: Synology 1512+
Hi @Sniper8952
Are you facing this problem always? So, not even once you are able to connect to your device? If that is the case, then please download the logfiles by clicking "Download Support Information" and directly send it to me.
Highlighted
Posted by
Electron
Synology 1019+
Same problem, no ID and no password on 1019+.
Restart, reinstall app, same problem
Highlighted
Posted by
Electron
Re: Synology 1019+
same here
Highlighted
Posted by
Henagon
@arpitjindal,
couldn't reply sooner, sorry about that.
Yes, it's a virtual DSM, hence any logfile is probably obsolete.
Nonetheless, that VM, together with a couple more VMs, runs on a 716+II DSM to comply with SOC (separation of concerns, i. e. 1 VM per concern, e. g. DBs, website files, webserver, etc.) which helps minimize both, security vulnerabilities and admin tasks like updates.
I therefore request immediate support for virtual DSM as it's almost identical to any "real" DSM.
Highlighted
Posted by
Henagon
Operating System Health Monitoring
Is Health Monitoring supported on Synology devices? If so, how does one go about activating Operating System Health Monitoring on a Synology DS1812+ for example?
FYI, we are running version 2.3.7 of TeamViewer on the NAS.
Highlighted
Posted by
Electron
Is there a verssion that supports Synology NAS DS413 (Freescale chipset)?
Thanks in advance,
~Andrew~
Highlighted
Posted by
Henagon
I asked 1 year ago by when will come support for macOS and Android. I has been said it is on the roadmap.
Any news on that ?
Highlighted
TeamViewer Staff
Hi @ThreadRipper86
Thanks for the use case. We will look into it and try to find the solution as-soon-as-possible.
Highlighted
TeamViewer Staff
Re: Operating System Health Monitoring
Hi @kc6108
Operating System Health Monitoring is not supported on Synology Device.
