Announcements
First Step Guides
  1. Are you new to TeamViewer and Home Office and need some help? Check out our FAQ here.
  2. New to the Remote Access Plan? Find our first steps FAQ here.
  3. Are you new to blizz and online meetings or classes and need some help? Check out our FAQ here.
Highlighted
Posted by
Henagon
Re: IoT Remote AppControl solution and Synology NAS boxes
sorry it is 213+
Highlighted
Posted by
Henagon
Can't connect to teamviewer
Can't connect to teamviewer,I ’m logged in as an administrator and I ca n’t change the options below.
Highlighted
Posted by TeamViewer Staff
TeamViewer Staff
Re: Can't connect to teamviewer
Hi @Tao173
Could you please provide us with more information in order to have a better understanding of the issue?
Maybe could send us a screenshot that explicitly shows the issue?
Tech Support IoT
Highlighted
Posted by
Henagon
Like this, I am logged in as an administrator, and I cannot open REMOTE TERMINAL,And I ca n’t access the device remotely, there are errors in the log files, I wo n’t upload the files, so the screenshots show you.
Highlighted
Posted by
Henagon
@arpitjindal wrote:
Hi @AndrewRH
No, unfortunately not. Currently, There are only for intel and arm chipset.
Like this, I am logged in as an administrator, and I cannot open REMOTE TERMINAL,And I ca n’t access the device remotely, there are errors in the log files, I wo n’t upload the files, so the screenshots show you.批注 2020-02-01 130331.png图片2.pngInkedA 2020-02-01 125308_LI.jpg
Highlighted
TeamViewer Staff
Hi @Tao173
Could you tell also witch model of Synology do you have?
And please go to my post from page 4. It is possible that the device is not assign to your account
Tech Support IoT
Highlighted
Posted by
Henagon
@mircea_c wrote:
Hi @Tao173
This device is DS918,and I have assigned it to my account
Highlighted
TeamViewer Staff
Hi @Tao173
As I could see from the pictures, the device is not assigned to your account. "Assigning to your account" and "adding to your contact list" are two different things. Please read the first page to how to assign the device to your account.
Highlighted
Posted by
Henagon
@arpitjindal wrote:
Hi @Tao173
When I tried to assign to my account, it showed that the password was wrong. I used the account and password shown in nas. I also tried my nas password, which was also incorrect. Could you please tell me what the password is? Thank you very much.
Highlighted
TeamViewer Staff
Hello @Tao173
Please could you delete the device from your “Computer and Contacts” and add the device again.
When you add the device, could you try with “Nearby contacts and devices”, if the device is in the same network?
With Nearby, the device is automatically assigned to the account.
Tech Support IoT
Highlighted
Posted by
Photon
Andreas,
Is this feature supported Synology Surveillance Station as well?
After connecting DSM, then I tried to run Surveillance Station, but could not access the applicantion.
Thanks,
Highlighted
TeamViewer Staff
Hi @KM-5
Unfortunately, the Synology Surveillance Station app is not accessible via TeamViewer connection. Apps that opening a new browser window will not work, so MailStation or VideoStation and the example you mentioned (just to name a few), will not be able to run.
Mircea
Tech Support IoT
