Hello
Last august I installed teamviewer for personal use on a small win10 fanless PC. It is (should be) h24 on and is configured to autorestart on power failure. Teamviewer on that PC is configured to mantain the same id and I access it via password.
Sometimes I connect to it just to check and set security cameras installed locally. Cameras are connected to a 4G router and can be reached from the web, but some settings are possible only by a local client, installed also on the fanless pc.
Some days ago teamviewer started to fail connection. It says that remote PC is offline. Is there anything I can do to check what's happened without going there? I can't go there until next easter, unfortunately.
Thank you for your help
Alberto
