Device alias resets after teamviewer upgrade?
Hello.
We are currently upgrading teamviewer host on all company computers from v10 to v15.
We uninstall the old v10 msi package, then install a new custom host package like this:
msiexec.exe /i "\\FILESERVER\Program\TeamViewer\TV15\TeamViewer_Host_XXXXXXX.msi" /qn SETTINGSFILE="\\FILESERVER\Program\TeamViewer\TV15\2020_v15.tvopt" CUSTOMCONFIGID=XXXXXXX APITOKEN=XXXXXXXX-XXXXXXXXXXXXXX /l "\\FILESERVER\Program\TeamViewer\TV15\log\%COMPUTERNAME%_tvlog.txt"
This works greats, v15 is up and running and the upgraded device is still online in the teamviewer management console. The problem: the alias has changed/reset. For easy searching, we usually add the users name to the alias, like PC555 - Bob Smith. After the upgrade, the alias is reset to just PC555.
The documentations says this about the alias:
--alias [<name>] | Alias for the new device in the computers & contacts list. If the device is already in the contact list, no alias will be applied. |
In our case, the device is already in the contact list, so the alias should remain untouched. This does not happen, the default %computername% alias is applied.
Does "If the device is already in the contact list"" from the doc really mean "If the device alias is already in the contact list"? Wouldnt it be better to check if the teamviewer ID is already in the contact list, and then leave the alias alone? We aren't even using the --reassign option, and the teamviewer ID remains the same as before upgrading. The description field remains unchanged.
Any suggestions for workarounds that let us keep our custom device aliases when upgrading? Do we need to actually use the --alias assignment option in order to leave the alias unchanged, or is there another trick to this?
Hi @tkirk
Thank you for your post and welcome to our Community. ?
This is actually a good question. Since this is a more technical one, I'm sure @TV_Benjamin can explain the case properly.
I hope, he may take over. Feel free to contact us again if there are any further questions.
Wish you a great day.
Natascha ?♀️
Hello @tkirk,
thank you for your post.
The answer to this is actually pretty easy.
Please change the rollout script like shown below:
With the assignment parameter changed to --alias %UserName% it should show up as the users name instead of the %ComputerName% (this would be the standard setting)
If the device is already listed in your Computers & Contacts list TeamViewer will recognize the ID and change the Alias accordingly. (I just tested this on my VM to confirm)
Let us know if that worked for you.
Have a great day and enjoy your weekend.
Benjamin
