Hi! I'm unable to connect to my Raspberry Pi 4 running teamviewer-host. It used to work, but now I just get a "connecting" in the TV client and after a few minutes it says "connection cancelled". This happens both via "my computers" and via ID + password.
sudo teamviewer info gives:
TeamViewer 15.12.4 (DEB)
TeamViewer ID: <censored>
teamviewerd status ● teamviewerd.service - TeamViewer remote control daemon
Loaded: loaded (/etc/systemd/system/teamviewerd.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2020-12-13 14:58:02 CET; 23min ago
Process: 4290 ExecStart=/opt/teamviewer/tv_bin/teamviewerd -d (code=exited, status=0/SUCCESS)
Main PID: 4292 (teamviewerd)
Tasks: 17 (limit: 4915)
CGroup: /system.slice/teamviewerd.service
└─4292 /opt/teamviewer/tv_bin/teamviewerd -d
Dec 13 14:58:02 raspberrypi systemd[1]: Starting TeamViewer remote control daemon...
Dec 13 14:58:02 raspberrypi systemd[1]: teamviewerd.service: Can't open PID file /run/teamviewerd.pid (yet?) after start: No such file or directory
Dec 13 14:58:02 raspberrypi systemd[1]: Started TeamViewer remote control daemon.
I tried reinstalling the package, reinstalling but also deleting the global.conf, nothing works.
Can you help me?
