2017/07/27 10:49:54.200 5948 10028 G2 Logger started.
2017/07/27 10:49:54.214 5948 10028 G2 StringCompare locale: German_Germany.1252
2017/07/27 10:49:54.224 5948 10028 G2+ Thread: Main
2017/07/27 10:49:54.716 5948 10028 G2+ GetSimpleDisplayCertNameFromFile: Found cert name: 'TeamViewer GmbH'.
2017/07/27 10:49:54.853 5948 10028 G2+ GetSimpleDisplayCertNameFromFile: Found cert name: 'TeamViewer GmbH'.
2017/07/27 10:49:55.185 5948 10028 G2+ GetSimpleDisplayCertNameFromFile: Found cert name: 'TeamViewer GmbH'.
2017/07/27 10:49:55.785 5948 10028 G2+ GetSimpleDisplayCertNameFromFile: Found cert name: 'TeamViewer GmbH'.
2017/07/27 10:49:56.106 5948 10028 G2+ GetSimpleDisplayCertNameFromFile: Found cert name: 'TeamViewer GmbH'.
2017/07/27 10:49:56.295 5948 10028 G2+ GetSimpleDisplayCertNameFromFile: Found cert name: 'TeamViewer GmbH'.
2017/07/27 10:49:56.302 5948 10028 G2+ HttpRedirectionProtocol: Successfully registered
2017/07/27 10:49:56.302 5948 10028 G2+ Thread: IOServiceWorker_0
2017/07/27 10:49:56.302 5948 10028 G2+ Thread: IOServiceWorker_1
2017/07/27 10:49:56.302 5948 10028 G2+ Thread: IOServiceWorker_2
2017/07/27 10:49:56.302 5948 10028 G2+ Thread: IOServiceWorker_3
2017/07/27 10:49:56.302 5948 10028 G2+ Thread: IOServiceWorker_6
2017/07/27 10:49:56.302 5948 10028 G2+ Thread: IOServiceWorker_5
2017/07/27 10:49:56.302 5948 10028 G2+ Thread: IOServiceWorker_9
2017/07/27 10:49:56.302 5948 10028 G2+ Thread: IOServiceWorker_10
2017/07/27 10:49:56.302 5948 10028 G2+ Thread: IOServiceWorker_4
2017/07/27 10:49:56.302 5948 10028 G2+ Thread: IOServiceWorker_7
2017/07/27 10:49:56.302 5948 10028 G2+ Thread: IOServiceWorker_13
2017/07/27 10:49:56.302 5948 10028 G2+ Thread: IOServiceWorker_11
2017/07/27 10:49:56.302 5948 10028 G2+ Thread: IOServiceWorker_12
2017/07/27 10:49:56.306 5948 10028 G2+ Thread: IOServiceWorker_8
2017/07/27 10:49:56.306 5948 10028 G2+ Thread: IOServiceWorker_14
2017/07/27 10:49:56.306 5948 10028 G2+ Thread: IOServiceWorker_15
2017/07/27 10:49:56.314 5948 10028 G2 CustomConfigurationUpdater::ReadInitialConfigurationId: Found configuration "nyaq5uc".
2017/07/27 10:49:56.314 5948 10028 G2 ProxySearch::GetCurrentTVProxySettings: did not find settings in path #1
2017/07/27 10:49:56.314 5948 10028 G2 ProxySearch::GetCurrentTVProxySettings: did not find settings in path #2
2017/07/27 10:49:56.330 5948 10028 G2 ProxySearch: no PAC script detected via WPAD
2017/07/27 10:49:56.549 5948 10028 G2+ CustomConfigurationUpdater::DownloadRevisionNumber: Downloaded revision number 4
2017/07/27 10:49:56.549 5948 10028 G2+ CustomConfigurationUpdaterGUI::IsUpdateRequired(): nyaq5uc updateRequired 0
2017/07/27 10:49:56.556 5948 10028 G2 Monitors: Generic Non-PnP Monitor, \\.\DISPLAY1, 1024x768 (0,0), flags=3, dpi=96
2017/07/27 10:49:56.650 5948 10028 G2+ GetSimpleDisplayCertNameFromFile: Found cert name: 'TeamViewer GmbH'.
2017/07/27 10:49:56.732 5948 10028 G2+ GetSimpleDisplayCertNameFromFile: Found cert name: 'TeamViewer GmbH'.
2017/07/27 10:49:56.756 5948 10028 G2+ GetSimpleDisplayCertNameFromFile: Found cert name: 'TeamViewer GmbH'.
2017/07/27 10:49:56.760 5948 10028 G2+ TVDesktopApplicationWin::LoadResourceDLLs: Current used TV language set to: de
2017/07/27 10:49:56.791 5948 10028 G2+ GetSimpleDisplayCertNameFromFile: Found cert name: 'TeamViewer GmbH'.
2017/07/27 10:49:56.791 5948 10028 G2 CMain::LoadResourceDLLs(): No custom resource dll found
2017/07/27 10:49:56.791 5948 10028 G2 InterProcessBase::SecureNetwork created
2017/07/27 10:49:56.803 5948 10028 G2+ ConfigurationHub::SetDecisionDataValueInternal(2): Setting ClientLanguage to "de"
2017/07/27 10:49:56.803 5948 10028 G2+ ConfigurationHub::SetDecisionDataValueInternal(2): Setting SessionDyngateID to 153604271
2017/07/27 10:49:56.803 5948 10028 G2+ ConfigurationHub::SetDecisionDataValueInternal(2): Setting UserLanguage to "de"
2017/07/27 10:49:56.806 5948 10028 G2+ Thread: TimedCallback
2017/07/27 10:49:56.810 5948 10028 G2 tvshared::WindowsSessionStateManager::WindowsSessionStateManager(04FD27D8) state 0
2017/07/27 10:49:56.810 5948 10028 G2+ tvshared::WindowsSessionStateManager::setUserLoggedIn(04FD27D8): changed to: 1
2017/07/27 10:49:56.834 5948 10028 G2! Service is installed but not running
2017/07/27 10:50:02.668 5948 10028 G2 Chat::Stop: Stopping chat
2017/07/27 10:50:02.668 5948 10028 G2 TAF::Handler::ctor: TAF initialized. MM=40
2017/07/27 10:50:02.679 5948 10028 G2!! ConfigurationHub::HandleRegistrationResponse(): registering for feature 5 failed with error 2
2017/07/27 10:50:02.679 5948 10028 G2!! ConfigurationHub::HandleRegistrationResponse(): registering for feature 6 failed with error 2
2017/07/27 10:50:02.679 5948 10028 G2!! ConfigurationHub::HandleRegistrationResponse(): registering for feature 9 failed with error 2
2017/07/27 10:50:02.679 5948 10028 G2!! ConfigurationHub::HandleRegistrationResponse(): registering for feature 10 failed with error 2
2017/07/27 10:50:02.679 5948 10028 G2 interprocessbase::SecureNetwork destroyed
2017/07/27 10:50:02.679 5948 10028 G2+ HttpRedirectionProtocol: http successfully unregistered
2017/07/27 10:50:02.679 5948 10028 G2+ HttpRedirectionProtocol: https successfully unregistered
2017/07/27 10:50:02.679 5948 10028 G2!! SpecificThreadCallWin::~SpecificThreadCallWin(): m_PostCallbacks not empty
2017/07/27 10:50:02.701 7100 5760 G2 Logger started.
2017/07/27 10:50:02.711 7100 5760 G2 StringCompare locale: German_Germany.1252
2017/07/27 10:50:03.199 7100 5760 G2 CustomConfigurationUpdater::ReadInitialConfigurationId: Found configuration "nyaq5uc".
2017/07/27 10:50:03.202 7100 5760 G2 ProxySearch::GetCurrentTVProxySettings: did not find settings in path #1
2017/07/27 10:50:03.202 7100 5760 G2 ProxySearch::GetCurrentTVProxySettings: did not find settings in path #2
2017/07/27 10:50:03.217 7100 5760 G2 ProxySearch: no PAC script detected via WPAD
2017/07/27 10:50:03.383 7100 5760 G2 Monitors: Generic Non-PnP Monitor, \\.\DISPLAY1, 1024x768 (0,0), flags=3, dpi=96
2017/07/27 10:50:03.497 7100 5760 G2 CMain::LoadResourceDLLs(): No custom resource dll found
2017/07/27 10:50:03.497 7100 5760 G2 InterProcessBase::SecureNetwork created
2017/07/27 10:50:03.505 7100 5760 G2 tvshared::WindowsSessionStateManager::WindowsSessionStateManager(050F87B8) state 0
2017/07/27 10:50:03.508 7100 5760 G2! Service is installed but not running
2017/07/27 10:50:03.512 7100 5760 G2 TAF::Handler::ctor: TAF initialized. MM=40
2017/07/27 10:50:03.551 7100 5760 G2 MsHtmlVersionInfo: 11.0.14393.1480
2017/07/27 10:50:03.693 7100 5760 G2! AsioSettings::FindExternalIP: found 0 external IPs instead of 1!
2017/07/27 10:50:03.696 7100 5760 G2 UpdateOnlineState newOnlineValue 1
2017/07/27 10:50:03.700 7100 5760 G2! AsioSettings::FindExternalIP: found 0 external IPs instead of 1!
2017/07/27 10:50:03.707 7100 5760 G2 DriverConnector::InitAdapterConfig: succeeded with instance id {404B1E2A-0781-4703-9811-20440E73A707} (1)
