Remote control of a tablet
AlainLevy
Posts: 1 Newbie
My tablet is an Elo 4 15" running on Android 10.
I can't control the screen through TeamViewer, I can only look at the screen after I acknowledge on the tablet that the Host app will record or control my screen.
1. Is there a specific setting to be able to control the screen (click and write)?
2. How can I skip the acknowledge part on my tablet?
Hello @AlainLevy,
Elo is not fully supported in terms of remote control.
If your device does not prompt you for downloading an add-on, it means that it is not available for this specific device.
You can request the development of this add-on by contacting our dedicated team via this link:
