The button doesn't even respond on the device i'm trying to boot from, any solution?
postscript to my 8:43am note: I have added my laptop's Teamviewer ID to my Desktop's Teamviewer list of known machines.
My desktop has Wake on Lan enabled in BIOS. My Ethernet adapter (wired to router) has "allow this device to wake the computer" enabled and "allow the computer to turn off this device" DISabled, so the card is always on. I am running Windows 10 with TPM enabled, ready for Windows 11. I have forwarded UDP port 9 to my desktop. I have not seen anything about opening port 9 in the firewall, which makes sense, since the signal is supposed to come in before the firewall is started.
On my laptop, TeamViewer sees when my desktop is offline. I have setup for wake via domain name. When I click the icon to wake my desktop system, the icon blinks, but nothing happens. My desktop does NOT wake up.
The feature had worked properly beforehand and failed just this instance. The device I'm trying to access is (very) remote and this kind of malfunction stops my advance at work for at least a week given how inaccessible that pc is, I understand you can do nothing about this so thx for your time.
Hello @felonganiza,
I recommend reviewing the instructions and manual of the Wake-On-LAN feature:
There must be something wrong with the setup.
For some reason the only interface that provides a somewhat more detailed message is the browser version; it popped the message "The configured neighbors for waking the device up are offline". Is there any way to solve this??
See what's new at TeamViewer
