Can I update clients from the management console?
Can I push a setting change to multiple clients?
I really do not want to go to each (nearly 100) client, connect, then update, and then move to the next one. The whole point of a MANAGEMENT console, is to manage the clients en masse.
I do have other tools, so, if there is a way to set a registry key to enable the auto-update, let them all update, and then turn off again the auto-update again, that would be OK.
