How can you connect to other phone with out needing to always confirm
Hello @Zombiezii,
Thank you for posting here! 🌻
It will depend on which app you are using on the other phone.
If you are using QuickSupport, you will always need to confirm the connection.
If you don't wont to confirm the connection, you need to install TeamViewer Host on the other phone.
You can download the Host from the Play Store directly or from our website.
📌Note: TeamViewer Host is only available for smartphones running Android.
I hope this could help!
See what's new at TeamViewer
