Was wondering if anyone had any ideas how to solve a problem I have using TeamViewer. When I try to connect to someone this happens (se attached photo). Everything is a bit smaller in the center for the screen and frozen. I can use the controls at top, but also have serval bars that is just image's of it that don't work.
I have tried rebooting my pc, uninstalling TeamViewer (with remove settings) and deleted the thigs left in C:\Users\<username>\AppData\Roaming\TeamViewer and then reinstalled. But same problem happens. Then I tried updating to a insider build, same thing in that. Using the same account and connection to the host from a different PC works fine.
Anyone got ideas how to solve this?
