Hello ,
I have a problem with my VPN,
until yesterday all work,
today it does not work with any device , I stay in Tunisia
Hey there!
My name is Richard Gravener. I use many VPNs like . [removed per Community Guidelines]
I disagree, until the penultimate version, I had no problems, the vpn "Ping" and with "route add" I worked with more than seventy clients without problems. Now don't even "ping"
I can confirm that TeamViewer is not supported with the use of a VPN.
Please see more information about it here:
I hope this could at least answer the question why it is not working properly...
Yes it is correct ,
with the last version , I have this message on the drive :
Impossibile verificare la firma digitale dei driver richiesti per il dispositivo. È possibile che durante una modifica recente dell'hardware o del software sia stato installato un file danneggiato, con una firma non corretta o costituito da malware di origine sconosciuta. (Codice 52)
but I don't understand why.... I download 64 bit version as my win7 and if I check my teamviewer... there is write 32-bit.......
I uninstall all... also delete in the "regedit" (in a manual there is write this procedure) , but nothing
Hello @mosefrenguelli,
Just to be sure I understand your issue correctly.
First, you enable your VPN on your device. And then, you start TeamViewer and connect to a remote device.
And now, the connection can't be establish. Is this correct?
See what's new at TeamViewer
