when I run following command
rpm -qa | grep -i team
result is:
teamviewer9-9.0.xxxxx
but when I do:
rpm -e teamviewer9-9.0.xxxxx
it says :
package teamviewer9-9.0.xxxxx is not installed
The real problem is that, for some reason teamviewer stopped launching at startup and if I manually type the command teamviewer in the terminal, it says command not found, hence wanted to uninstall and re-install.
but before doing that, I don't want to delete the folder in /opt/teamviewer, and wanted to understand what is going on? and is there any other way of fixing this issue i.e. reenabling the teamviewer daemon.
the linux distro is: (SUSE Linux)
