I have a Samsung phone and need to use teamviewer to connect to my chromebook is this possible . I keep getting a message
This partner doesn't accept incoming connections
Hello @RayReddington1966,
Thank you for reaching out to us in TeamViewer Community and congrats on your first post! 🙌
Can you kindly check the setting on the remote device which is the Chromebook please.
The path is TeamViewer - GearWheel (âš™) - Advanced - Advanced settings for connections to this computer - Access Control - Full Access.
Can you kindly check and try again for remote connections. Hope it would work for you this time!
See what's new at TeamViewer
