We will be upgrading our teamviewer host clients in preparation to move our PCs from Win 10 to 11 (in-place upgrade). For many business reasons, we do not have auto update host clients set in our tensor policy. Thus, we need to mass install the new client.
1. I was told by TeamViewer support that client ID could (would most likely) change after the OS in-place upgrade. Is the ID guaranteed to change after the 10>11 upgrade? Anyone see this?  If the ID changes, would it happen right at first login of the user profile? Or sometime after?  What is odd is we’ve tested the OS upgrade on two systems with the 15.22 host client and the ID did not change and I was able to connect fine as before and do everything we always do with TeamViewer host.
2. The TeamViewer host client I have to upgrade all of our systems is 15.44.7.0. Is this the “best” version to use for Win 11 22H2?  Some host client versions were more problematic than others.
3. After the OS is upgraded to Win 11, I was told the client will lose its TeamViewer Tensor association (I’m paraphrasing here)? If this does happen, there would be a command line to run to “get them back” into our Tensor system. What is that? And hopefully that command, if needed, isn’t specific to each group a client might be in. If so, that would be a nightmare deployment as it’s much more difficult for us to know which group a system is in via Intune or SCCM.
4. Is there a host version compatible with the upcoming Win 11 23H2 release?
