macOS 14.0 stopped connecting when on Lock Screen
two
Posts: 3 ✭✭
For years I was able to access my MacBook at home (Screen locked, device put on charger). I've now updated to macOS 14 and suddenly this doesn't work anymore. I can only connect when the display is unlocked and showing my desktop. Having an unlocked device sitting at home is a huge security risk.
What setting do I need to change to make TeamViewer be able to connect again to my MacBook on macOS 14.0 when it's locked?
I found a setting that says like "Prevent sleep when the display is off" and enabled it. Not sure if it was enabled before but I think it works again now
1
1
