TeamViewer double click ... continued
This is a continue of the TeamViewer 11 thread: Teaviewer Double Click
I again have the "double click problem" with TeamViewer 12 (v12.0.71503) on both ends.
It is a much less persisting problem than before. I had it when i connected to my second "main" computer. I restarted this computer and it looked like the problem was solved again. Now i connect the other way around and i have this problem too, but more persistant, although it is better than with TV 11 and the TV 12 betas.
It looks like a timing problem, when the remote host is able to act soon enough everything seems fine, but if it takes a few seconds too long it is like the desired action is done only half the way ... difficult to explain :smileyfrustrated:
I have to excuse me, i didn't think about that i get windows insider builds on both affected systems. This was the reason of the problem, with the latest insider builds the problem disappeared again
»We are all born unique, but most of us will die as a copy.«7
