Remote connection is adjusting local audio volume
Why is a TeamViewer remote connection decreasing the audio playback on my PC?
I don't want the volume of other audio sources adjusted when I initiate a connection to a remote PC. Audio settings for remote connections & meetings are disabled a far as I can see.
Please provide a cheaper personal edition
  • JenW
    JenW Posts: 1,269 Senior Moderator
    Answer ✓
    Hi @Ian_C,
    Happy to see you posting again in our Community!
    Maybe the following workaround helps to fix your issue:
    Please right-click on the speaker's item in the tray menu ➜ Open Sounds ➜ Go to Communications and set the value to Do nothing. You can then confirm the settings and try it again.
    Hope this helps!
    Jen
  • JenW
    Answer ✓
    Hi @Ian_C,
    Hope this helps!
    Jen
  • Ian_C
    Ian_C Posts: 9
    Thanks Jen. That did help.
    Admittedly, I would have preferred a change in TeamViewer settings instead of a global setting in Windows.
  • JenW
    Hi @Ian_C,
    We're happy to read that it helped.
    We will forward your feedback internally to the dedicated team.
    Have a nice day,
    Jen
