There should be a method to prioritise a LAN connections in TeamViewer, connection requests are more stable within an internal network.
Hi @IT Help,
Thank you for your suggestion!
You can already configure how TeamViewer handles LAN connections through the Incoming LAN connections setting in the advanced settings of your TeamViewer client.
This gives you control over whether devices should communicate over the local network or via the TeamViewer network.
The available options are:
If you are managing multiple devices, this setting can also be enforced centrally through a TeamViewer policy using the rule "Incoming LAN connections". This allows administrators to ensure consistent behavior across their managed devices.
Let me know if this is what you were looking for. 😊
/JeanK
