Current version of teamviewer. COnnecitng to a remote pc with WIndows 10 pro. As soon as i enter passcode and connect, i can see the users dekstop for a couple of seconds, then my teamviewer disconnects and the remote pc screen goes black and acts like the desktop is locked out where user has to re-enter their password. I have tried uninstall then reinstall teamvoewer on the remote computer with no change
Amazing find! Worked like a champ!
how to remove vulcan runtime?
the "Admin Approval Mode for the Built-In Administrator account" is not under security settings>local policies>security options
is there other place where it is hiding?
thanks
Removing Vulkan Runtime Libaries from programs and features resolved the issue!
I have this issue on a nuc running windows home, so not pro and no nvidia.
I think I figured it out thanks to the reddit community.
Seems Vulkan runtime causes the issue. It's an nvidia driver component and so. Useless compared to being able to help your users.
Remove Vulkan runtime from programs and features, reboot.
Worked for me while none of these solution did.
Thank you very much, the solution worked for me !!!
Actually the problem started after windows 10 update and as per your solutions by enabling the "User Account Control: Use Admin Approval Mode for the built-in Administrator account" it worked.
Enabled means - The built-in Administrator account uses Admin Approval Mode. By default, any operation that requires elevation of privilege will prompt the user to approve the operation.
Note : just a small update along with this i have also enabled "Accounts: Administrator account status" , this security setting determines whether the local Administrator account is enabled or disabled.
i had same issue with some user. I removed user from local Administrator group which solved the problem for me
Oh I´m sorry, thanks for the info, have you found a solution for this issue? without removing security?
Thats not a fix that is removing security...
I think that I found a solution for this problem.
First, i know that this issue affects windows 10 Pro only and i really hope so because you can to modify a security policy that its in windows 10 pro not available in windows 10 home.
Solution: Run windows powershell or cmd as administrator, type "secpol.msc" without the quotes, that will open local security policy, go to security settings >local policies>security options > go to "Admin Approval Mode for the Built-In Administrator account" and enable it, reboot and try!
i am still having this issue it is now January any update?
Greetings:
We are still experiencing this issue, and while rebooting the machine does allow us to access once again, it's still annoying.
Do you have an update on the status of this problem?
Nate J.
Hi TeamViewer Community,Thank you all for your post’s.
We are investigating this issue and I wanted to give you and update on the current status:
As we cannot fix the bug on our side alone, we are currently not able to give you an ETA when this issue will be fixed. As soon as there is an update on a fix from Microsoft, we will inform you here. As a workaround for now, we can just recommend you to reboot your computer when this behavior appears.
Thank you for your understanding and your patience with this.
Best, Hendrik
I'm having the same issue too!!
VERY FRUSTRATING!!!
Does anybody have any idea? We are at a loss right now!
Have the exact same problem with a windows 10 pro computer when trying to access it via the installed teamviewer 9. I am using teamviewer 11. Has anyone found the solution to this issue?
I've been chasing this issue since late last week and thought I was the only person.
Only happens with some W10 clients but it is the same with every single remote support program I've tried (**third party content**etc).
I suspected a W10 update to be the cause but I'm having trouble narrowing down which one it may be.
I have the same issue with one Windows 10 Pro PC. Seems like no Problem in Teamviewer, because the same happens in every Remotesupport-Tool i've tried (**third party content** ...)
And btw, the screen locks not after a few seconds. It happens as soon as you try to move your mouse on the remote PC. Strange problem..
