This post is archived. Information may be outdated or no longer valid.
I use a TomTom Go 610 device on my MS Surface laptop. I have had to update the power settings for the Surface for Connected Standby and USB Selective suspend. The details for this can be found here,https://en.discussions.tomtom.com/map-installation-43/map-update-issues-go-live-1535-keeps-disconnecting-or-losing-communication-during-update-process-1010446
However, when I install Teamviewer I get the same symptoms. The TomTom device will not connect reliably. It disconnects frequently.To solve the problem I uninstall Teamviewer, run the TomTom updates and then re-install Teamviewer.Can anyone suggest a better solution?
