Not Ready. Please check your connection.
Greetings. I've been having this issue for a day now. Last midnight my connection to teamviewer from my pc has been lost and i cannot fix it. There are no firewall/antivirus blocking teamviewer and my ports are open. I can connect using teamviewer 8 that i've downloaded from another post about this topic. I've tried everything i can but i cannot fix it. I can also use my phone to connect to my remote pc's using the same wifi network. I am using windows 10
Things i've tried:
-Made sure ports are open
-Disabled firewall. No antivirus is present.
-Reinstalled it multiple of times.
-Killed all tasks and restarted teamviewer.
-Restarted services
-Did a clean uninstall along with regedit registries and all that
-Uninstalled then reinstalled network drivers.
-Tried to manually ping masterx.teamviewer.com adresses and fill the hosts file with the matching ip's.
-Tried to connect via proxy (and disabled it completely).
My log files are filled with these:
2017/12/13 20:05:30.529 4992 8600 S0! CProcessCommandHandlerMasterConnect[536]::HandleMasterConnect(): MasterConnect to 0.0.0.0 failed
2017/12/13 20:05:30.529 4992 8600 S0!! LookUpDNS failed for master14.teamviewer.com, socket error = 11001, Errorcode=11001
2017/12/13 20:05:30.529 4992 8600 S0!!!Connect to Master master14.teamviewer.com / failed!, Errorcode=11001
2017/12/13 20:05:30.529 4992 8600 S0!! CMasterConnectorAsio::HandleMasterResponseLogin(): MasterConnect failed. ErrorCode=10, Errorcode=11001
2017/12/13 20:05:33.530 4992 8600 S0 Activating Router carrier
2017/12/13 20:05:33.530 4992 8600 S0!!!CTcpConnectionBase[537]::HandleResolve(): Resolve failed, ping3.teamviewer.com, Error: system:11001
2017/12/13 20:05:33.530 4992 7156 S0 Activating Router carrier
2017/12/13 20:05:33.545 4992 10352 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: ping3.teamviewer.com
2017/12/13 20:05:33.545 4992 10352 S0!! Port443Connection::ConnectInternal: failed with HTTP status code = 0
2017/12/13 20:05:33.545 4992 8600 S0!! NetWatchdog: Port 443 proxy search failed! No working setting found.
2017/12/13 20:05:33.545 4992 8600 S0 Activating Router carrier
2017/12/13 20:05:33.560 4992 8336 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: ping3.teamviewer.com
2017/12/13 20:05:33.560 4992 8600 S0!! NetWatchdog: Port 80 proxy search failed! No working setting found. -- next log entries will be omitted --
2017/12/13 20:05:33.562 4992 8600 S0! CKeepAliveClientClient::HandlePing(): ping failed
2017/12/13 20:05:33.563 4992 8600 S0 Non-Commercial use
2017/12/13 20:05:33.563 4992 8600 S0 Resource-Language: en
2017/12/13 20:05:33.563 4992 8600 S0 Activating Router carrier
2017/12/13 20:05:33.563 4992 8600 S0 CProcessCommandHandlerMasterConnect[540]::CreateMasterConnect(): master9.teamviewer.com:80, Connection 540, proxy=''
2017/12/13 20:05:33.577 4992 10340 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: master9.teamviewer.com
2017/12/13 20:05:33.577 4992 8336 S0! CProcessCommandHandlerMasterConnect[540]::HandleMasterConnect(): MasterConnect to 0.0.0.0 failed
2017/12/13 20:05:33.577 4992 8336 S0!! LookUpDNS failed for master9.teamviewer.com, socket error = 11001, Errorcode=11001
2017/12/13 20:05:33.577 4992 8336 S0!!!Connect to Master master9.teamviewer.com / failed!, Errorcode=11001
2017/12/13 20:05:33.577 4992 8336 S0!! CMasterConnectorAsio::HandleMasterResponseLogin(): MasterConnect failed. ErrorCode=10, Errorcode=11001
2017/12/13 20:05:36.577 4992 8600 S0 Activating Router carrier
2017/12/13 20:05:36.578 4992 8600 S0!!!CTcpConnectionBase[541]::HandleResolve(): Resolve failed, ping3.teamviewer.com, Error: system:11001
2017/12/13 20:05:36.578 4992 8336 S0 Activating Router carrier
2017/12/13 20:05:36.592 4992 8600 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: ping3.teamviewer.com
2017/12/13 20:05:36.592 4992 8600 S0!! Port443Connection::ConnectInternal: failed with HTTP status code = 0
2017/12/13 20:05:36.593 4992 10352 S0 Activating Router carrier
2017/12/13 20:05:36.607 4992 7156 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: ping3.teamviewer.com
2017/12/13 20:05:36.609 4992 8336 S0! CKeepAliveClientClient::HandlePing(): ping failed
2017/12/13 20:05:36.609 4992 8336 S0 Non-Commercial use
2017/12/13 20:05:36.609 4992 8336 S0 Resource-Language: en
2017/12/13 20:05:36.609 4992 8336 S0 Activating Router carrier
2017/12/13 20:05:36.609 4992 8336 S0 CProcessCommandHandlerMasterConnect[544]::CreateMasterConnect(): master11.teamviewer.com:80, Connection 544, proxy=''
2017/12/13 20:05:36.622 4992 8336 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: master11.teamviewer.com
2017/12/13 20:05:36.623 4992 10352 S0! CProcessCommandHandlerMasterConnect[544]::HandleMasterConnect(): MasterConnect to 0.0.0.0 failed
2017/12/13 20:05:36.623 4992 10352 S0!! LookUpDNS failed for master11.teamviewer.com, socket error = 11001, Errorcode=11001
2017/12/13 20:05:36.623 4992 10352 S0!!!Connect to Master master11.teamviewer.com / failed!, Errorcode=11001
2017/12/13 20:05:36.623 4992 10352 S0!! CMasterConnectorAsio::HandleMasterResponseLogin(): MasterConnect failed. ErrorCode=10, Errorcode=11001
2017/12/13 20:05:39.623 4992 8600 S0 Activating Router carrier
2017/12/13 20:05:39.623 4992 8600 S0!!!CTcpConnectionBase[545]::HandleResolve(): Resolve failed, ping3.teamviewer.com, Error: system:11001
2017/12/13 20:05:39.623 4992 10352 S0 Activating Router carrier
2017/12/13 20:05:39.638 4992 8600 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: ping3.teamviewer.com
2017/12/13 20:05:39.639 4992 8600 S0!! Port443Connection::ConnectInternal: failed with HTTP status code = 0
2017/12/13 20:05:39.639 4992 10352 S0!! NetWatchdog: Port 443 proxy search failed! No working setting found. -- 2 previous log entries omitted --
2017/12/13 20:05:39.639 4992 10352 S0 Activating Router carrier
2017/12/13 20:05:39.655 4992 10340 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: ping3.teamviewer.com
2017/12/13 20:05:39.655 4992 10352 S0!! NetWatchdog: Port 80 proxy search failed! No working setting found.
2017/12/13 20:05:39.657 4992 10352 S0! CKeepAliveClientClient::HandlePing(): ping failed
2017/12/13 20:05:39.657 4992 10352 S0 Non-Commercial use
2017/12/13 20:05:39.657 4992 10352 S0 Resource-Language: en
2017/12/13 20:05:39.657 4992 10352 S0 Activating Router carrier
2017/12/13 20:05:39.657 4992 10352 S0 CProcessCommandHandlerMasterConnect[548]::CreateMasterConnect(): master5.teamviewer.com:80, Connection 548, proxy=''
2017/12/13 20:05:39.669 4992 10352 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: master5.teamviewer.com
2017/12/13 20:05:39.669 4992 8600 S0! CProcessCommandHandlerMasterConnect[548]::HandleMasterConnect(): MasterConnect to 0.0.0.0 failed
2017/12/13 20:05:39.669 4992 8600 S0!! LookUpDNS failed for master5.teamviewer.com, socket error = 11001, Errorcode=11001
2017/12/13 20:05:39.669 4992 8600 S0!!!Connect to Master master5.teamviewer.com / failed!, Errorcode=11001
2017/12/13 20:05:39.670 4992 8600 S0!! CMasterConnectorAsio::HandleMasterResponseLogin(): MasterConnect failed. ErrorCode=10, Errorcode=11001
2017/12/13 20:05:42.670 4992 8600 S0 Activating Router carrier
2017/12/13 20:05:42.670 4992 8600 S0!!!CTcpConnectionBase[549]::HandleResolve(): Resolve failed, ping3.teamviewer.com, Error: system:11001
2017/12/13 20:05:42.671 4992 7156 S0 Activating Router carrier
2017/12/13 20:05:42.685 4992 10352 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: ping3.teamviewer.com
2017/12/13 20:05:42.685 4992 10352 S0!! Port443Connection::ConnectInternal: failed with HTTP status code = 0
2017/12/13 20:05:42.685 4992 8600 S0!! NetWatchdog: Port 443 proxy search failed! No working setting found.
2017/12/13 20:05:42.686 4992 8600 S0 Activating Router carrier
2017/12/13 20:05:42.701 4992 10352 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: ping3.teamviewer.com
2017/12/13 20:05:42.701 4992 8336 S0!! NetWatchdog: Port 80 proxy search failed! No working setting found.
2017/12/13 20:05:42.704 4992 8336 S0! CKeepAliveClientClient::HandlePing(): ping failed
2017/12/13 20:05:42.704 4992 8336 S0 Non-Commercial use
2017/12/13 20:05:42.704 4992 8336 S0 Resource-Language: en
2017/12/13 20:05:42.704 4992 8336 S0 Activating Router carrier
2017/12/13 20:05:42.705 4992 8336 S0 CProcessCommandHandlerMasterConnect[552]::CreateMasterConnect(): master12.teamviewer.com:80, Connection 552, proxy=''
2017/12/13 20:05:42.717 4992 8336 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: master12.teamviewer.com
2017/12/13 20:05:42.717 4992 10352 S0! CProcessCommandHandlerMasterConnect[552]::HandleMasterConnect(): MasterConnect to 0.0.0.0 failed
2017/12/13 20:05:42.717 4992 10352 S0!! LookUpDNS failed for master12.teamviewer.com, socket error = 11001, Errorcode=11001
2017/12/13 20:05:42.717 4992 10352 S0!!!Connect to Master master12.teamviewer.com / failed!, Errorcode=11001
2017/12/13 20:05:42.717 4992 10352 S0!! CMasterConnectorAsio::HandleMasterResponseLogin(): MasterConnect failed. ErrorCode=10, Errorcode=11001
2017/12/13 20:05:45.717 4992 7156 S0 Activating Router carrier
2017/12/13 20:05:45.717 4992 7156 S0!!!CTcpConnectionBase[553]::HandleResolve(): Resolve failed, ping3.teamviewer.com, Error: system:11001
2017/12/13 20:05:45.718 4992 10352 S0 Activating Router carrier
2017/12/13 20:05:45.732 4992 7156 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: ping3.teamviewer.com
2017/12/13 20:05:45.732 4992 7156 S0!! Port443Connection::ConnectInternal: failed with HTTP status code = 0
2017/12/13 20:05:45.733 4992 10352 S0!! NetWatchdog: Port 443 proxy search failed! No working setting found.
2017/12/13 20:05:45.733 4992 10352 S0 Activating Router carrier
2017/12/13 20:05:45.748 4992 8336 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: ping3.teamviewer.com
2017/12/13 20:05:45.748 4992 10352 S0!! NetWatchdog: Port 80 proxy search failed! No working setting found. -- next log entries will be omitted --
2017/12/13 20:05:45.749 4992 10352 S0! CKeepAliveClientClient::HandlePing(): ping failed
2017/12/13 20:05:45.750 4992 10352 S0 Non-Commercial use
2017/12/13 20:05:45.750 4992 10352 S0 Resource-Language: en
2017/12/13 20:05:45.750 4992 10352 S0 Activating Router carrier
2017/12/13 20:05:45.750 4992 10352 S0 CProcessCommandHandlerMasterConnect[556]::CreateMasterConnect(): master13.teamviewer.com:80, Connection 556, proxy=''
2017/12/13 20:05:45.764 4992 7156 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: master13.teamviewer.com
2017/12/13 20:05:45.764 4992 10340 S0! CProcessCommandHandlerMasterConnect[556]::HandleMasterConnect(): MasterConnect to 0.0.0.0 failed
2017/12/13 20:05:45.765 4992 10340 S0!! LookUpDNS failed for master13.teamviewer.com, socket error = 11001, Errorcode=11001
2017/12/13 20:05:45.765 4992 10340 S0!!!Connect to Master master13.teamviewer.com / failed!, Errorcode=11001
2017/12/13 20:05:45.765 4992 10340 S0!! CMasterConnectorAsio::HandleMasterResponseLogin(): MasterConnect failed. ErrorCode=10, Errorcode=11001
2017/12/13 20:05:48.765 4992 10352 S0 Activating Router carrier
2017/12/13 20:05:48.765 4992 10352 S0!!!CTcpConnectionBase[557]::HandleResolve(): Resolve failed, ping3.teamviewer.com, Error: system:11001
2017/12/13 20:05:48.765 4992 10340 S0 Activating Router carrier
2017/12/13 20:05:48.779 4992 10352 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: ping3.teamviewer.com
2017/12/13 20:05:48.779 4992 10352 S0!! Port443Connection::ConnectInternal: failed with HTTP status code = 0
2017/12/13 20:05:48.779 4992 7156 S0 Activating Router carrier
2017/12/13 20:05:48.795 4992 7156 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: ping3.teamviewer.com
2017/12/13 20:05:48.796 4992 10340 S0! CKeepAliveClientClient::HandlePing(): ping failed
2017/12/13 20:05:48.797 4992 10340 S0 Non-Commercial use
2017/12/13 20:05:48.797 4992 10340 S0 Resource-Language: en
2017/12/13 20:05:48.797 4992 10340 S0 Activating Router carrier
2017/12/13 20:05:48.797 4992 10340 S0 CProcessCommandHandlerMasterConnect[560]::CreateMasterConnect(): master2.teamviewer.com:80, Connection 560, proxy=''
2017/12/13 20:05:48.810 4992 10352 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: master2.teamviewer.com
2017/12/13 20:05:48.810 4992 10340 S0! CProcessCommandHandlerMasterConnect[560]::HandleMasterConnect(): MasterConnect to 0.0.0.0 failed
2017/12/13 20:05:48.810 4992 10340 S0!! LookUpDNS failed for master2.teamviewer.com, socket error = 11001, Errorcode=11001
2017/12/13 20:05:48.810 4992 10340 S0!!!Connect to Master master2.teamviewer.com / failed!, Errorcode=11001
2017/12/13 20:05:48.810 4992 10340 S0!! CMasterConnectorAsio::HandleMasterResponseLogin(): MasterConnect failed. ErrorCode=10, Errorcode=11001
2017/12/13 20:05:51.811 4992 7156 S0 Activating Router carrier
2017/12/13 20:05:51.811 4992 7156 S0!!!CTcpConnectionBase[561]::HandleResolve(): Resolve failed, ping3.teamviewer.com, Error: system:11001
2017/12/13 20:05:51.811 4992 10340 S0 Activating Router carrier
2017/12/13 20:05:51.826 4992 7156 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: ping3.teamviewer.com
2017/12/13 20:05:51.826 4992 7156 S0!! Port443Connection::ConnectInternal: failed with HTTP status code = 0
2017/12/13 20:05:51.826 4992 8392 S0!! NetWatchdog: Port 443 proxy search failed! No working setting found. -- 2 previous log entries omitted --
2017/12/13 20:05:51.826 4992 8392 S0 Activating Router carrier
2017/12/13 20:05:51.841 4992 8600 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: ping3.teamviewer.com
2017/12/13 20:05:51.841 4992 8392 S0!! NetWatchdog: Port 80 proxy search failed! No working setting found.
2017/12/13 20:05:51.843 4992 8392 S0! CKeepAliveClientClient::HandlePing(): ping failed
2017/12/13 20:05:51.843 4992 8392 S0 Non-Commercial use
2017/12/13 20:05:51.843 4992 8392 S0 Resource-Language: en
2017/12/13 20:05:51.844 4992 8392 S0 Activating Router carrier
2017/12/13 20:05:51.844 4992 8392 S0 CProcessCommandHandlerMasterConnect[564]::CreateMasterConnect(): master7.teamviewer.com:80, Connection 564, proxy=''
2017/12/13 20:05:51.858 4992 8600 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: master7.teamviewer.com
2017/12/13 20:05:51.858 4992 8392 S0! CProcessCommandHandlerMasterConnect[564]::HandleMasterConnect(): MasterConnect to 0.0.0.0 failed
2017/12/13 20:05:51.858 4992 8392 S0!! LookUpDNS failed for master7.teamviewer.com, socket error = 11001, Errorcode=11001
2017/12/13 20:05:51.858 4992 8392 S0!!!Connect to Master master7.teamviewer.com / failed!, Errorcode=11001
2017/12/13 20:05:51.858 4992 8392 S0!! CMasterConnectorAsio::HandleMasterResponseLogin(): MasterConnect failed. ErrorCode=10, Errorcode=11001
Please help me get through this, as i need to have access to my remote pc's through my main pc's asap! Cheers.
