Keyboard combination caused problems
I was looking for a keyboard combination for a program I was using via Teamviewer, but instead of passing the correct keyboard combination to the intended program, it completely **bleep** up my view of the remote PC on Teamviewer. It was either a combination of:
Ctrl-Alt-Home, or
Ctrl-Alt Shift-Home
The net effect was that now my remote view only shows a portion of the remote screen, so I have to use the sliders on the edge of the screen to see the full remote PC desktop. The remote screen is very narrow, so I can't see the full screen all at once now. What is the keyboard combination that will fix this issue? If there is no keyboard combination to fix the problem, how do I fix the remote view?
Thanks,
Rick
