I've enable Teamviewer VPN in the settings but the option to click on VPN while before connecting isn't there?
What could this be? Please help me.
Thank you!
Hi, I have the same problem,
Please indicate the steps to solve it.
Ok so The VPN is not a part of the free version. I have a paid vision and I do not have the VPN option. And I really really need it!
Thanks for your post @Skenn and welcome to our Community 😊
You are not able to see the the VPN feature because it is no longer part of the free version.
Please find here more information: TeamViewer Remote’s Free Version Redesign
Best, Alena
I have tried reinstalling VPN and TeamViewer a couple of times but still not able to see the vpn in the control remote computer tab.(version 15.44.6)
(screenshot edited by a moderator as per our guidelines- please always protect your private data)
Update:
It appears that after manually uninstalling and reinstalling the VPN driver via Options / Advanced has fixed the issue.
VPN is now an option listed under "Control Remote Computer".
Still having issues finding VPN option.
I am running version 15.39.6 64-bit on Windows 10. VPN driver is installed on both PC's. I am signed into TeamViewer using free account. VPN option is not listed under "Control Remote Computer". VPN option is not listed under Connection or Extras.
Can you please provide guidance on how to start a VPN connection.
Thanks!
Hello everyone,
Thank you for all the questions about this topic!
Updates have been implemented into TeamViewer VPN. Therefore, please make sure that:
Let us know how it goes, and don't hesitate in posting any additional questions. 🙋♀️
Have a great day!
Best, Carol 👩🏻🦰🌷
what you said is right must be an update issue. Thanks for the information.
I am having the same issue. The VPN option was there on version 15.37.8 but at least the last 2 versions took it away. I have verified that the VPN driver is installed. The only 2 options in "Control Remote Computer" drop down menu are Remote Control and File transfer. If I reinstall version 15.37.8, the VPN option is on the list. If I reinstall 15.38.3 or 15.39.3, the VPN options is gone.
No vpn option after update
Hey… anyone was able to fix the problem?
i installed the vpn driver on mine and my customer windows computer and still Dont have the vpn option on the teamviewe?
please help tnx
Hello, I have been using the VPN option for a few months on the free version but today I can't select the VPN option, I am only offered the remote control and file transfer option. However, the VPN drivers are well installed on both computers. Can you help me? Thank you in advance.
there is no 3rd vpn option after updating to latest verion and yes vpn driver is installed successfully
version 15.38.3
Hello Community!
I'm having an issue with Teamviewer where when I connect to a PC the Start VPN option is grayed out, however the adapter is installed and if I try to log in to that same PC from a different Teamviewer I can indeed activate the VPN driver.
Steps taken :
Reinstall VPN Driver - no result
Reinstall TeamViewer - no result
Restarted Teamviewer Service - no result
Edited Registry - no result
Updated Windows - no result
I think I have a similar issue, maybe the same. I installed vpn for 2 machines, I'm able to connect from one PC to the other, but when I try to connect from the other PC the button to connect isn't there. I can't find the reason. So the connection only works one way!
