Using TV 13 from a Windows 10 machine to a Windows 7 remote machine. I've got some apps that require ctrl-alt-letter (e.g., ctrl-alt-A for my password manager) combos, and they only seem to work on the local machine. For instance, when typing ctrl-alt-A into the TV window, it's the local password manager app that gets the command, not the remote one.
I have Send Key Combinations turned ON in TV settings. Is there some other setting I need to toggle?
