Met problem:
For a partner, to whom I wish to connect, I do not reach there.
I have the following error message:
No connection to the partner!
The partner is not connected to the router(route planner).
Code of error: Waitforconnectfailed
Teamviewer, on the distant pc, starts well with Windows.
I installed(settled) the last version on the distant pc, nothing could be done.
The solution that I found is to leave Teamviewer with a right click and to boost(relaunch) him from the menu to start.
At this moment there everything works normally.
Can bring me to you a less binding solution to the met problem?
Thank you,
Best Regards, Jean Pierre.
I do not speak English at all, I use a translator.
