Hi All
I was wondering if someone here can help me in this situation T_T
im using two 3G USB Modem on the same network with different static IPs
First USB Modem IP >> 11.36.55.56
Second USB Modem IP >> 11.36.55.57
i can use 'em anywhere inside my country
i tried to connect both together with TeamViewer and it worked just fine by just enabling the option Incoming LAN Connections : Accept Exclusivley this is the only way both connects each other which means i'm using USBs which are offline of internet but online with network
but i want to try something different -.-
i brought a LTE/3G Sharing Router and connected one of my USB Modem to router and configured router page and USB Modem connected successfully and signal strength is good
shared a WIFI network then joined it with different laptops
1ST Laptop IP >> 11.36.55.60
2ND Laptop IP >> 11.36.55.61
3RD Laptop IP >> 11.36.55.62
they all connect with each other via TeamViewer PERFECT
But when i try to connect 'em with the other USB Modem which has the IP >> 11.36.55.57
doesn't connect at all
Error message > > > {Partner could not be contacted at the given network adress.}
so i just need to know is there a way to make it connect ^_^ ??!
i hope i did not start this topic in a wrong section
any help would be appreciated,Thanks i advnace
Sorry for my leak of English words
2018/02/05 16:28:08.441 6336 5108 G1 Trying connection to 1.20.23.46, mode = 1
2018/02/05 16:28:08.456 2440 2432 S0 Activating Router carrier
2018/02/05 16:28:13.457 2440 2432 S0 CTcpConnectionBase[37]::HandleConnectTimeout(). Connect timed out to 11.36.55.60:5938
2018/02/05 16:28:13.457 2440 2436 S0! CTcpConnectionBase[37]::HandleConnect: Connect aborted to dest-ip 11.36.55.60:5938 with error system:995.
2018/02/05 16:28:13.457 6336 4652 G1!! LoginOutgoing: ConnectFinished - error: ConnectFailed
2018/02/05 16:28:20.896 6336 5108 G1 CMainWindow::InitCloseTV(): Prepare to close TeamViewer
2018/02/05 16:28:20.903 6336 5108 G1 CMainWindow::OnDestroy(): Closing TeamViewer
2018/02/05 16:28:20.905 6336 5108 G1 Chat::Stop: Stopping chat
2018/02/05 16:28:20.905 6336 5108 G1 ChatManager::UnregisterIncomingCommandRegistration: destroying incomingCommandRegistration
2018/02/05 16:28:20.905 6336 5108 G1 IncomingChatCommandRegistration::Stop: disconnecting ready state properties
2018/02/05 16:28:20.905 6336 5108 G1 ChatManager::~ChatManager: destroyed
2018/02/05 16:28:20.905 6336 5108 G1 IncomingBetterChatCommandHandler::IncomingBetterChatCommandHandler: destroyed
2018/02/05 16:28:20.907 6336 5108 G1 ~MachineHooks: refcount = 0
2018/02/05 16:28:20.907 6336 5108 G1 MachineHooks: Stopping Loaders!
2018/02/05 16:28:20.908 6088 6568 L32 Exit
2018/02/05 16:28:20.910 2756 6580 L64 Exit
2018/02/05 16:28:20.923 6336 6520 G1 ApiServer::ApiMain: API thread stopped.
2018/02/05 16:28:20.924 2440 2444 S0 CInterProcessNetwork: Received DisconnectIPC from processID 6336 (ProcessType: 2 in Session 1) with reason 1
2018/02/05 16:28:20.925 2440 2444 S0 Process 6336 in session 1 has terminated
2018/02/05 16:28:20.928 6336 1612 G1 CTcpProcessConnector::HandleRead(): Socket gracefully closed (PID=2440)
2018/02/05 16:28:20.928 6336 1612 G1 CTcpProcessConnector::CloseConnection(): PID=2440
2018/02/05 16:28:20.929 6336 1612 G1! InterProcessBase::EventFunctionInternal(): IPC-Connection Closed
2018/02/05 16:28:20.929 6336 1612 G1 CTcpProcessConnector::CloseConnection(): PID=2440
2018/02/05 16:28:20.929 2440 2444 S0 CTcpProcessConnector::HandleRead(): Socket gracefully closed (PID=6336)
2018/02/05 16:28:20.929 6336 5108 G1 interprocessbase::SecureNetwork destroyed
2018/02/05 16:28:20.929 2440 2444 S0 CTcpProcessConnector::CloseConnection(): PID=6336
2018/02/05 16:28:20.929 2440 2444 S0 CInterProcessNetwork::NewInterProcessDataAvailable(): ConnectionClosed session=1 ptype=2
2018/02/05 16:28:20.929 2440 2444 S0 UpdateOnlineState m_ManualStop
2018/02/05 16:28:20.929 6336 5108 G1!! SpecificThreadCallWin::~SpecificThreadCallWin(): m_PostCallbacks not empty
2018/02/05 16:28:20.930 2440 6380 S0 TeamViewer is going offline!
2018/02/05 16:28:20.930 2440 6380 S0 RemoteSessionManager::ClearAllRemoteSessions(): RemoteSession Count: 0
2018/02/05 16:28:20.937 6336 5108 G1 InterProcessConfigurationHub::SendToConfigurationHandler(): IPC not available, could not send command: CC=1 CT=110
